Obx 3/4" Spacer
Tried the "search button" on the forum to know more about the 3/4" OBX spacer with no luck... :icon8:
Do you have any idea if this one will clear the standard Nissan 350Z tower bar? http://i13.ebayimg.com/06/i/000/bb/23/9699_1_b.JPG As seen on ebay... Blox Racing Intake Manifold Spacer VQ35- 03-05 Nissan 350z/ Infiniti G35 3/4" thickness Helps increase manifold's capacity and lowers intake air temp. Power and throttle response also increases Made out of Thermal Polymer Easily installs between the factory intake manifold Part# BXIM-40200 Why is this so cheap compared to other spacers (e.g. MD) ?? It can be purchased for $89.95 on ebay and many other sites. Anyone using it on here? Thanks, Zsan |
WTF? I've never heard of it but if the 1/2" spacer won't clear without spacers, I'd imagine a 3/4" wouldn't fit even with spacers on there without the strut bar touching the hood.
no won't clear
no way
I would never put anything from OBX on my car.
Sooner or later you will learn, you get what you pay for usually. If saving a $100 is worth doing it twice, then hell yeah, good pick mang. |
Originally Posted by HondaKiller
i agree, that shat is garbage.
Sooner or later you will learn, you get what you pay for usually. If saving a $100 is worth doing it twice, then hell yeah, good pick mang. I'd try it out but I didn't have better things to spend money on. |
^^^ +1
I would think it would be fine till the heat dries it out - couple years worth of use maybe, less if FI...
bump anyone else tried it?
Does it also come 'ribbed' for her pleasure? Lol~ :icon11:
Read the dyno graphs at Motordyne. Not only is 3/4" too thick to fit under the oem bar, it creates too much volume in the intake. It's not an optimum thickness.
I'm pretty sure it's not 3/4"... the BLOX spacer is 1/2". Unless they make two, but I doubt it. would 3/4" even clear the hood?
