MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   Driver's Window Help (https://my350z.com/forum/maintenance-and-repair/589362-drivers-window-help.html)
OldManZ350 Jan 17, 2014 01:39 PM
2003 350z
My windows have always worked fine, never a problem, then a few days ago, Nothing. It also does not move when you open the door. No up, No Down. Passanger is fine.
Anything Simple?
Thanks,
TimRod
AdvanZ33 Jan 17, 2014 01:52 PM
Window motor probably crapped the bed. You can try the reset procedure before paying for a new motor but it's likely you will need a new one anyhow.
Spike100 Jan 17, 2014 02:20 PM
I agree with our Moderator. You are likely looking at a motor replacement.
A search will show you how to clean the motor and extend its life. I did this, but it was a short term fix. I replaced the motor after the second failure, and this appears to be a long term fix.
The passenger window motor lasts much longer unless you always have a rider opening and closing the door.
--Spike
dcains Jan 17, 2014 02:39 PM
--Spike
It's funny that the passenger side window motor failed on my '08 with 50K miles, and that door has barely been opened since the car was new, and here in Florida I rarely roll down the windows. My wife likes us to drive her TL-S whenever we go out, so she's been in my Z maybe 5 times. The driver's window is still fine, now at 55K, and it's my daily car.
jhc Jan 17, 2014 02:41 PM
I did the window motor clean method 18 months ago, good ever since on dd.
Search "window", gl
OldManZ350 Jan 17, 2014 03:11 PM
How dod you do the Reset?
Thanks
TimRod
dcains Jan 17, 2014 03:13 PM
https://my350z.com/forum/attachments/...-procedure.pdf
AdvanZ33 Jan 17, 2014 03:14 PM
Thanks
TimRod
This is the DIY I used to replace mine. Scroll down to post #17 for the reset button location.
https://my350z.com/forum/maintenance...dow-motor.html
OldManZ350 Jan 17, 2014 03:14 PM
Thanks
Joaquin350 Jan 27, 2014 07:59 AM
Hmm...I have been having this issue with my '03 on the drivers side as well. It wont go slightly down when I open the door and it just stays frozen the whole time and when I roll the window down and roll it back up, it goes back down halfway :dunno: I am going to try the reset procedure and if all fails then I will have to get a new motor.
350zmark Jan 14, 2016 07:40 PM
Window problem 2003 350Z
The driver side window on ny 2003 350Z works intermittently. Symptoms window does not move up when door is closed. Window does not roll down. However, if I open the door and push down on the window then operate the window switch the window rolls down. It will not go back unless I push down on the window again. If the motor is bad why does it work at all? Could the reset procedure fix this issue? Also, how difficult is it to take off the door panel? Are any special tools required? Any assistance is appreciated.
travlee Jan 15, 2016 04:49 AM
double post, first one was in forum feedback section, and it got moved
https://my350z.com/forum/maintenance...2003-350z.html
