Driver side window problem 2003 350Z
Old Jan 14, 2016 | 08:01 PM
350zmark's Avatar
350zmark
Default Driver side window problem 2003 350Z
Hello everyone,
I'm looking for some guidance regarding a window problem on my 2003 350Z touring model. Symtoms: (1) window works intermittently; (2) window does not move up when door is closed; (3) when window is not working, if I open the door and push down on the window, then operate the window switch the window starts to go down. Sometimes it will go back up. If it does not go back up I push down on the window then operate the window switch and the window goes back up. I don't think the motor is bad because it would not work at all if the motor was shot. Will resetting the motor fix this issue? Also, how difficult is it to take off the door panel? Are there any special tools required to take off the door panel? Any assistance/guidance is appreciated.
Mark
Old Jan 15, 2016 | 04:24 AM
travlee's Avatar
travlee
Master
replace the window motor it is going out, everything that you asked has been asked many times on this forum. learn to post in the correct section please, you posted this in the feedback and suggestions for the forum, should be in the maintenance and repair section
Old Jan 15, 2016 | 04:27 AM
verdict.'s Avatar
verdict.
I think this is the second post you've posted in Feedback & Suggestions...
Moved to Maintenance & Repair
Captain_Chris
Jan 23, 2016 08:50 PM
EnjukuRacing
Jan 13, 2016 06:27 AM
terrj
Jan 8, 2016 04:51 AM
DEMoLITIoN
Jan 3, 2016 08:17 AM
