WTF .. ABS Code C1109?
Just changed out my rotors and pads up front, ... and now my car wont rev past 1000 RPM's unless I clear the code.... I see an ABS code of:
C1109 This is really urking the **** out of me... I can drive the car for about 30 seconds .. stop pull over .. clear the code, then restart the car .. drive for 30 seconds... wash rinse repeat. I am beginning to hate my Z. :icon20: EDIT: Also.. the ABS BRAKE VDC and SLIP lights are on. |
Did you connect EVERYTHING back up after changing the rotors and pads??
Is the brake fluid full? I had the ABS, VDC, Slip light when I first did my BBK. I filled the brake fluid, but it sucked it up and wanted more. Added more, lights went off. But if you didn't remove the caliper, I guess you shouldn't have that problem.
Did you knock off one of the ABS-TCS-VDC wheel speed sensors, that might do it? May be you accidentally did something to them, check their connections etc ?
See, this is why you should stick to working on your beater man... Leave the Z to the guys with the computers & the $80 labor charge...
J/K.. I hope you get this resolved man. You call Gene or Noah to ask? |
J/K.. I hope you get this resolved man. You call Gene or Noah to ask? On the way to the dealership, I had to clear it 3 times.. I live about 3 ~ 4 miles from dealer. We hooked up the Consult II to my car and started to drive it around.... and.. NADA.. NOTHING.. ZIP... it would not re-throw the damn code. Drove it for about 15 minutes with moderate to heavy braking. Still nothing. Which worries me even more.. When is this monster going to rear its ugly head again..... Does anyone know or have a link to all the engine / abs / body Codes? |
C1109 Speed Control Actuator Assembly Cable Release Failure
At least that is what the Net says the OBD-II codes means. Try this http://www.dodgetrucks.org/docs/OBD-II%20Codes.pdf (Yes I know it says Dodge... but I validated it with 4 other sites....) or this http://www.autoelectric.ru/diagnosti...ool/ccodes.txt |
