CvD's Vortech Thread ..
I decided to plunge into the realm of FI a few months ago and have been documenting my build on another forum since then. I figured it was time I started a thread here and shared with you guys and gals what's happening with my Z.
To make a long story short, I started with a GReddy TT kit. After much thought, consideration and procrastination, I sold it. I then picked up a Vortech tuner kit instead. So, here's a run down of the mods and photos of the installation follow. Vortech Satin Kit 2.87 Pulley UTEC with MAP Sensor Deatchwerks 600CC Injectors Walbro 255 Pump TopSpeed Headers TopSpeed Test Pipes AAM Reflash Stillen TD Exhaust (up for trade ... any takers? :D) Hotchkis Springs Hotchkis Swaybars Stoptech Braided Lines Axxis Ultimates Pads Axis Hiro 19x8.5 / 19x9.5 UR Flywheel Southbend Stage II Cluch Braided Clutch Line Motul Clutch Fluid Motul Brake Fluid Kenwood Audio Components Infinity Speakers CG Lock (best mod ever - not really a mod, but whatever) JIC Carbon Strut Brace (in the mail) Stillen Front Splitter Probably a bunch of other misc things that I'm forgetting ... Anyway, on with the pics: https://img179.imageshack.us/img179/...sc05939bt2.jpg Before any work started: http://img370.imageshack.us/img370/5316/dsc06025lk2.jpg Fuel pump installation and modification .. http://img360.imageshack.us/img360/5792/dsc06026xk4.jpg Bumper and hood removed. http://img360.imageshack.us/img360/1927/dsc06029pu1.jpg Tapping the upper oil pan for the drain line. http://img135.imageshack.us/img135/5475/dsc06034nw2.jpg http://img381.imageshack.us/img381/8286/dsc06035lx1.jpg Charge pipe (installed correctly :lol: ). http://img381.imageshack.us/img381/5563/dsc06036fb3.jpg Some rock-n-roll from my son. http://img442.imageshack.us/img442/9736/dsc06038hj0.jpg |
A few more of the SC and bracket installed.
http://img442.imageshack.us/img442/3307/dsc06037dc7.jpg http://img291.imageshack.us/img291/1714/dsc06040lw6.jpg Upper plenum removed: http://img529.imageshack.us/img529/2110/dsc06074ds2.jpg Lower plenum removed: http://img513.imageshack.us/img513/5876/dsc06095ci1.jpg Peeking into the intake valves: http://img205.imageshack.us/img205/159/dsc06097dh9.jpg Power steering cooler stock location: http://img264.imageshack.us/img264/4249/dsc06076ed7.jpg Power steering cooler relocated: http://img252.imageshack.us/img252/2185/dsc06077eu2.jpg FMIC installed: http://img261.imageshack.us/img261/6866/dsc06080tz0.jpg http://img401.imageshack.us/img401/208/dsc06081az3.jpg |
http://img258.imageshack.us/img258/58/dsc06084ng0.jpg
http://img407.imageshack.us/img407/1600/dsc06088ib3.jpg http://img337.imageshack.us/img337/161/dsc06089aw2.jpg http://img206.imageshack.us/img206/6527/dsc06093ty9.jpg 3.33 on the left, 2.87 on the right ... http://img208.imageshack.us/img208/1446/dsc06170pc7.jpg Oil feed line setup: http://img507.imageshack.us/img507/3438/dsc06171lq1.jpg Oil return line: http://img508.imageshack.us/img508/9384/dsc06173nt1.jpg A peek up at the crank and windage tray: http://img529.imageshack.us/img529/3057/dsc06174hr9.jpg Deatchwerks 600CC injectors: http://img410.imageshack.us/img410/9154/dsc06175ns8.jpg Yep, I'm still a ricer ... http://img208.imageshack.us/img208/5007/dsc06176cr2.jpg |
And that's where I'm at until tomorrow. Things left to do ..
1. Install injectors 2. Reinstall oil pan 3. Install UTEC 4. Nut-n-bolt the car, put the rest of the misc things back on (manfold, etc) 5. Hook up the laptop and build a base map for leak down testing. 6. Tune ... 7. ???? 8. Profit!!! |
Oh yeah, anyone have tips on removing the crank pulley? I have an UR pulley on there now and need to put the stock one back on. I cannot get the bolt loose, it just spins the crank when I try.
Also, I'm assuming it's threaded normally as well (leftey loosey). |
Originally Posted by Car vs. Driver
(Post 6442244)
Also, I'm assuming it's threaded normally as well (leftey loosey). I remember members saying it wasnt a good idea to use an aftermarket pulley with a supercharged car. I could be remembering wrong though. ~Dv8 |
No it isn't, it spins the SC slower ... which is why I'm putting the stock one back on. I just cannot for the life of me get the crank bolt loose!
Theres 2 ways to do it.
using a large breaker par and a cheater bar. Park the car and put it in gear, no ebrake. Use either 1st or reverse(gear depends on whether your breaking it loose or tq'ing it down). Break the bolt loose. or, a bit risky but works well. Lift the car in the air. Place a breaker bar on the but. Lower the car slightly so that the breaker bar is touching the ground and cannot rotate. The breaker bar needs to be pointing towards the driver side wheel. With the car out of gear, ebrake on, brakes applied........crank the car in slow pulses. The nut should break loose in a few attempts. BTW, which belt layout do you have? Looks like the old style but i cannot tell. 93 inch belt? |
Using the stock Vortech layout for now, may change that up if I get slip ...
Thanks for the tips, tried with the car in 1st and reverse, it still spins the crank. But that struck me as really odd. |
What i meant is that there are two vortech belt layouts for the non revup motors. I have the shorter one and need to figure out belt sizing to run a smaller pulley but theres not alot of info out there on it.
Slipping clutch? doubtful. The pulley will turn a few degrees to get the slop out. If you use a large cheater bar and the pulley still rotates and the car moves/lifts then youve got bigger issues. The key hole is either messed up or the bolt was put on with some lock tite or seized into the crank. Theres a flywheel inspection cover on the drivers side. Its pita to get to with just the car on jacks. You can take the cover off, and wedge a long bar in theres with a flat tip to prevent flywheel from rotating. That will stop the motor for sure. |
Why the switch from the Greddy kit?
Here's the setup I'm running ...
http://kahn.bol.ucla.edu/stock_belt_setup.jpg Not sure the exactly length on the belt I have for th 2.87, it's BANDO #6PK2375. Although, even once I get the stock crank pulley back on, it seems like it might be too long for some reason. Hopefully I'll figure that out today as soon as I get into the garage and start working. |
Originally Posted by Alberto
(Post 6443751)
(Post 6443769)
Honestly ... I'm lazy. Doing all the work myself and I just didn't feel like pulling the motor this winter to get the TT kit installed.
Vortech is ten time easier..but Greddy is 2X more fun... its a trade off that I opted to go Vortech myself.
good luck, nice pics, pm or call if you have any questions along the way. |
(Post 6443751)
Nice.... It's about time you put up some photos and details of your build. Great job. if you need a hand some weekend lemme know.. Road Trip.. Your on the list to visit when the Z is outta the shop (s)..... |
Thanks man! We definately need to meet up once the cars are done. I'll shoot you a PM when I schedule my tune if you want to drop by for the fun :)
(Post 6447550)
Quick update in pictures of what I managed to get done last night. Wife was sick all day so I didn't get a chance to get to work until after my kids went to bed.
Fuel rails & stock injectors: https://farm4.static.flickr.com/3139...754986.jpg?v=0 Deatchwerks on the left, stock on the right: https://farm4.static.flickr.com/3196...a887c1.jpg?v=0 DW's installed in the rails: https://farm4.static.flickr.com/3013...c94b7d.jpg?v=0 Close up of the DW: https://farm4.static.flickr.com/3027...eb1e73.jpg?v=0 Couple of the reassembled engine bay: https://farm3.static.flickr.com/2065...193192.jpg?v=0 https://farm4.static.flickr.com/3253...afd2f8.jpg?v=0 |
Its looking good.
| All times are GMT -8. The time now is 10:53 PM. |
