Any suspension suggestions
Old Feb 19, 2008 | 10:12 PM
blackmagic612's Avatar
blackmagic612
Default Any suspension suggestions
Was wondering if you guys had any ideas of what would be a good start to tuning up the suspension.
Old Feb 19, 2008 | 11:14 PM
350ZTheStandard's Avatar
350ZTheStandard
Check your tire pressure
defines your goals
ask a smarter question with your defined purpose
use the search feature
give us the car details, year, model, stock tires or aftermarket
USE THE SEARCH FEATURE
Old Feb 24, 2008 | 06:15 PM
datsunHEAD's Avatar
datsunHEAD
If your looking for a all out race car (which I doubt)coilovers,rear caster arm,tie rods,tune your camber,toe and caster but just for a good street car I would say anything over a spring/shock combo is overkil but that's just my 0.4 cents
Old Feb 24, 2008 | 06:41 PM
ZDi[R]tY3's Avatar
ZDi[R]tY3
Welcome to the forum
If your just starting out I would say you will have to figure out what your budget is for 1,
As far as your use I'm guessing it'll be for a daily driven Z.
Z's suspension can be bit tricky at times depending on your wheels size & tires size & what your planning on using this suspension for?
So your best bet would be letting us know what size wheels & offset your planning on rolling on & what size tires are you planning on rolling on & what would this suspension upgrade will be used for?
You could start your planning from there ...
Old Feb 25, 2008 | 05:16 PM
BornSlippyZ's Avatar
BornSlippyZ
Everybody here has different setups...but if you plan to lower your car w/lowering springs, replace the OEM shocks with performance shocks of your choice you'll save yourself some heart ache and some cash.
Old Feb 25, 2008 | 08:31 PM
forced_04's Avatar
forced_04
this is ot I know, but anyone around here buy the BC coilovers. I have been hearing good things about them, and am looking for an excuse to pull the trigger
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
