FS: 700+ Wheel Hp Twin Turbo Nissan 350z, Custom built by Forged Performance
Old Mar 15, 2012 | 12:08 PM
D350Z10's Avatar
D350Z10
Default 700+ Wheel Hp Twin Turbo Nissan 350z, Custom built by Forged Performance
Hello,
$29,000 SHIPPED
$28,000 Picked Up
Car Mileage: 32,000, Built Motor miles: 12,000, Turbo Miles: 3,000
Uploaded with ImageShack.us
Car Information:
Here are the details of my one of a kind custom built 2004 Twin Turbo Nissan 350z, the only Nissan item on this car is the rear badge. I am the only owner of this car and it was built to my specifications, I took delivery of the car April 24th 2004. The car has been garage kept its entire life, only been driven on sunny days. The car literally is in perfect condition, the exterior of the car is 9 out of 10 and the interior still lingers of new car smell. I have spent 6 years building this car to what it has become; the car has won numerous car shows, events and magazines. But not only does it have the looks, it has the power to back it up. If you research the car on my350z forums, you will find that it was the fastest car in the Top Dog Airstrip event in Hendersonville, NC. The car produces 700 wheel horsepower; this is power directly to the ground and makes 800 hp @ the crankshaft without any drive train loss. It was built by the best performance shop specializing in Nissan 350z's, Forged Performance. Sharif the owner and operator of the establishment will answer any serious inquiries about the build and process. The car was officially completed in April of 2009, meaning all the trail and error was done before the end result. It has been equipped with the highest caliber of automotive parts. The motor is fully forged built V6 3.563L, with 12,000 miles. The engine is capable of handling 1000hp. I have invested over $80,000 into this vehicle, I have a complete binder with all of documents in regards to the build (dyno charts, sales receipts, service reports. etc)
https://my350z.com/forum/forced-indu...rip-event.html Link to Top Dog Airstrip Event
http://www.forgedperformance.com/ The Shop
The dyno graph shown in the pictures 692whp was @ 23psi, Sharif and I increased the boost and adjusted the timing since then
Please email me at @ diseffect1069@yahoo.com (I will answer any questions in regards to my car and if further requested will arrange Sharif of Forged Performance to answer any and all questions.
Specifications:
Exterior:
-Original and Complete DO LUCK body kit from Japan
-Limo tint all all windows except windshield
-Custom radio antenna
-Tinted 08 led tail lights
-Rear Fender modification for 305X30X19 wheels and tires
-Tein Hood Dampeners (hood shocks)
Wheels and Suspension / Braking:
-Volk Phantom Formula Silver Limited Edition wheels (no more production extremely rare and valuable)
-Rotora 6 piston front Big Brake Kit with 14in Rotors cross drilled and slotted
-Rotora 4 piston rear Big Brake Kit with 14in Rotors cross drilled and slotted
-RE40 Neo Chrome extended lug nuts with lock (RARE)
-Volk RE30 Limited Edition Center Caps
-Toyo R888 Tires 305X30X19 95 % tread left REAR
-Toyo T1R 265X30X19 95% tread left FRONT
-Buddy Club Coilover System (ride height adjustable and 12 way dampening control)
-Hotchkis Front and Rear Sway bars
-Crawford Engine Sway Bar
-Suspension tuned by Forged Performance (allignment,ride height, dampening)
-SPL Rear Camber arms (+- 3 camber)
Engine Management System and Interior Data Devices:
-HKS F-Con V PRO v3.3
-HKS Air Intake Inlet Sensor
-HKS Intake Air Temp. / Pressure Sensor
-HKS Intake Air Temp. / Sensor Mount 1/8pt
-HKS Pressure Sensor Super Wide Range
-AF Knock Amp New Version 2008
-HKS FCON VPro Harness 350z
-HKS FCON Navigator Pro for V-pro and iS
-HKS EVC Boost Controller v6 / Knock Amp with paint
-Custom Gauge mount for boost controller and knock amp
-Defi BF Amber Series Gauges with controller (EGT,BOOST,FUEL PRESSURE, OIL PRESSURE, COOLANT TEMP) all runs are recordable real time
-Innovative Wide Band
Engine / Drivetrain and Performance:
-Greddy Twin Turbo Kit Complete with Intercooler
-HTA 83mm upgraded Turbo Chargers built for Forced Performance (each turbo can handle 500whp)
-Tail 38mm Wastegates
-External Wastegate Dump Kit
-3in down pipes
-True Dual 3in AAM Exhaust
-Arias Extreme Duty Pistons (.020 overbore)
-Cosworth Intake Manifold (Carbon Fiber end caps)
-Crower Extreme Duty Connecting Rods
-ARP Extreme Duty Head Stud Kit L19
-HKS Metal Head Gasket 97mm
-ATS TRIPPLE CARBON CLUTCH (98% life remaining)
-Motul 15w50 Synthetic Oil
-AAM Oil Pan Spacer
-CJM Stage 2 Fuel Return System
-CJM Twin Fuel Pump Assembly
-1000cc Injectors
-Jim Wolf C8 Camshaft (turbo spec)
-Jim Wolf Spring and Shim Kit
-Snow Performance Methanol Injection kit
-Forged Performance s1 shortblock assembly kit
-Koyo Radiator
-B&M Short Throw Shifter
-Nismo Thermostat
-FP turbo oil filters
-Evans Zero Water Coolant
-Nissan Rear Coolant Bypass System
-AAM Greddy Oil Line kit
-Nissan Rod Bearing set-tri
-Nissan Main bearing set-tri
-Cosworth Thrust bearings std
-Nissan Engine Overhaul gasket kit
-Premium Heat wrapp on manifolds and hot piping
-Unorthodox Complete Pulley kit (UR 3 pulley kit)
-Orange Samco Hose Kit
-Grounding Kit
-NGK step two colder spark plugs
-Crawford Oil Cap
-Greddy High Pressure Radiator Cap
Interior:
-Sunset Lemans leather seats with seat heaters
-Alpine IVA D300 pop out head unit (DVD/TV/MP3/NAV) BYPASS switch enabled!
-Alpine Type R Component and Co-axil Speakers
-JL 300 by 4 watt amplifier
-Nismo Carbon Fiber Shift ****
-Custom 3 pillar gauge cluster
-Custom 3 A pillar gauge cluster
-Custom center council gauge cluster
-Code Alarm System (roll windows down or up, open gas cap, headlights, all from remote)
-Code Alarm Sensitivity Controller
Attached Thumbnails 700+ Wheel Hp Twin Turbo Nissan 350z, Custom built by Forged Performance-my350z_sale.jpg
Old Mar 15, 2012 | 08:45 PM
Josh|Swag's Avatar
Josh|Swag
Beautiful. Words can't provide justice to the car.
GLWS.
Old Mar 16, 2012 | 05:06 AM
VQpwr03z's Avatar
VQpwr03z
I was hoping to see this beast this year at zdayz. Awesome car GLWS!
Old Mar 17, 2012 | 09:03 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
I remember seeing this beast at ZDays. Such a nice/clean ride. Good luck with the sale.
Old Mar 18, 2012 | 08:19 AM
eltness350's Avatar
eltness350
The Untouchable
cant believe you r sellin it dil! wish u the best of luck bro!
Old Mar 18, 2012 | 08:40 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
GLWS! Mind me asking wheel sizing & offsets? Free bump!
Old Mar 18, 2012 | 08:49 AM
macspeed702's Avatar
macspeed702
damn your taking a big hit on the car. really nice build
if you had the some stock parts, i would do a part out and get some money back
Old Mar 18, 2012 | 12:11 PM
D350Z10's Avatar
D350Z10
19 X 9.5 Front 265/30/19 Toyo T1-R
19 X 10.5 Rear 305/30/19 Toyo R888
Not sure about the offset.
Old Mar 18, 2012 | 11:20 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks! Ordered new wheels/tires with similar sizing. Good luck with sale!!!! Beautiful car.
Old Mar 18, 2012 | 11:39 PM
OCMan's Avatar
OCMan
"My price is FIRM" What is your price?
Old Mar 19, 2012 | 07:17 AM
D350Z10's Avatar
D350Z10
Originally Posted by ocman
"my price is firm" what is your price?
$40,000
Old Mar 19, 2012 | 03:15 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Looks so clean...as usual. Man you keep that thing so spotless.
Old Mar 20, 2012 | 01:46 PM
Socalbred's Avatar
Socalbred
So whats next? What are you trying to buy to replace something this built? Not trying to get away from the sale, but she seems perfect...
Old Mar 20, 2012 | 01:58 PM
FlushedOut's Avatar
FlushedOut
oh my god....
Old Mar 20, 2012 | 02:21 PM
D350Z10's Avatar
D350Z10
I plan on purchasing either a 2013 turbo porsche, new m5 or a r8gt.
Old Mar 20, 2012 | 02:53 PM
AroundMyHorn's Avatar
AroundMyHorn
Absolutely gorgeous.
Old Mar 20, 2012 | 04:58 PM
taywan's Avatar
taywan
good looking ride!!
GLWS
Old Mar 24, 2012 | 03:57 AM
tgunsg35's Avatar
tgunsg35
Subscribed.
Old Mar 24, 2012 | 07:54 AM
jumpin800agl's Avatar
jumpin800agl
8 to 11
Great car. I've seen this car in action. Owner is very meticulous.
Old Apr 3, 2012 | 07:51 AM
D350Z10's Avatar
D350Z10
Thanks everyone! I appreciate the kind words.
