FS: lots of Z parts (some aftermarket, lots of OE)
Old Oct 7, 2008 | 08:27 AM
first350's Avatar
first350
Post FS: lots of Z parts (some aftermarket, lots of OE)
Sold my Z this past weekend w/ most of the autoX gear on it...here's what I have sitting in my garage. at this point, I'm NOT WILLING TO SHIP. All offers welcome...some stuff is worth $$ and I'm not going to sell for cheap, but other stuff I just want out of my garage.
350Z items:
Z items;
WHEELS:
- Enkei RP02 17X9 +35mm W/ 275/40/17 Hankook Ventus R214's C70 R-comps. ($1,000)
The rims are incredibly light, something around 16.9lbs/ea – they’re in good condition, but have some nicks/rubber marks on them. The tires are Hankook’s softest R-compound which are great for autoX. They’ve been heat cycled enough that they’re no longer competitive, so they’ve great for practice/track days, or just fun road trips. There’s plenty of rubber left for lots of autoXs or a handful for track days.
http://s19.photobucket.com/albums/b1...t-IMG_2859.jpg
http://s19.photobucket.com/albums/b1...angle_zoom.jpg
Rota Torque 18X8 +35 w/ worn Falken 615's 255/18 $300
-these are OE sizes, guaranteed to fit, and great if you're wanting to run stock classes for autoX. The tires are around the wear bars - 2 are slightly below, 2 are barely above.
http://s19.photobucket.com/albums/b1...t=DSCN0075.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0074.jpg
Two 17” OE rims (no tpms). $100 (tires are at the belts) I had picked these up w/ the intent of putting some drag radials on them...
MotorDyne Throttle Body Coolant bypass($5):
http://s19.photobucket.com/albums/b1...t=DSCN0059.jpg
Work wheels blue anodized valve stems ($5): (Pending sale to Alvin)
http://s19.photobucket.com/albums/b1...t=DSCN0058.jpg
JIC seat slider $100: allows you to mount a seat to the OE mounting points and still have the adjustability Fwd/Aft. (does not come with Aluminum L brackets)
http://s19.photobucket.com/albums/b1...t=DSC02712.jpg
’03-’05 350Z clear corners $50
I know they fit ’03-’05 for sure – they may also fit later years too.
http://www.vividracing.com/catalog/j...50z-p-944.html
http://s19.photobucket.com/albums/b1...t=DSC03390.jpg
http://s19.photobucket.com/albums/b1...t=DSC03389.jpg
JIC Rear Camber adjustable Controller arms $250
-had these on and they allowed me to run the correct Toe/Camber needed…but realized I read my SCCA rules incorrectly, so I have to go back to stock.
Part # Z33RCA, “Rear Camber Adjustable Control Arm Nissan 350Z Z33”, Cost: 448.00
http://jic-magic.com/ViewProduct.asp...47&CarMakeID=7
installed: http://i19.photobucket.com/albums/b1...s/DSC02704.jpg
OE parts: I had planned to bring my Z back to stock when the lease finished…I was able to sell it as it, so I’ve got lots of OE parts that are in great condition.
Muffler - $40
Mid-pipe - $40
Headers - $40
http://s19.photobucket.com/albums/b1...t=DSCN0066.jpg
Crank/Alt/PS pullies and belts $10 removed at 6K miles...been sitting in a box ever since - belts feel decent, but not sure how long they'll last.
flywheel/clutch $130 (removed at 18K miles – great condition)
http://s19.photobucket.com/albums/b1...t=DSCN0062.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0061.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0060.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0065.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0064.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0063.jpg
oe intake box $30 (removed at 3K miles…filter in great condition)
http://s19.photobucket.com/albums/b1...t=DSCN0071.jpg
upper plenum $50 (great condition, perfect for doing your own mods)
http://s19.photobucket.com/albums/b1...t=DSCN0069.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0068.jpg
oe sways and bushings $50 (removed at 7K miles)
http://s19.photobucket.com/albums/b1...t=DSCN0067.jpg
oe shifter $50 (perfect condition – removed at 2K miles)
http://s19.photobucket.com/albums/b1...t=DSCN0073.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0072.jpg
oe spark plugs $5 (removed at 15K miles…still worked great.) http://s19.photobucket.com/albums/b1...t=DSCN0056.jpg
oe lug nuts $5
http://s19.photobucket.com/albums/b1...t=DSCN0057.jpg
vlsd $50 (removed at 20K miles…does not include housing…)
http://s19.photobucket.com/albums/b1...t=DSCN0052.jpg
cup holder $5
http://s19.photobucket.com/albums/b1...t=DSCN0070.jpg
mud flaps $5 (super black)
Front bumper plastic inserts $5 (great for brake ducts)
http://s19.photobucket.com/albums/b1...t=DSCN0054.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0053.jpg
bumper foam pieces $5
lower plenum collector gasket $5:
http://s19.photobucket.com/albums/b1...t=DSCN0055.jpg
Stereo stuff:
Zenclousres Type-S custom subwoofer sealed enclosure $25
*does not include amp rack
http://i19.photobucket.com/albums/b1...m/DSC02241.jpg
Brake stuff: --> all are for '03-'05 non-brembo brakes
2 full sets of OE style rotors - some need to be resurfaced, others are decent. $10 for everything!
Raybesto (Front ST41, Rear ST43) - 50% left, $40. Pads for '03-'05 front and rear.
I used these at several tracks - OE pads just fade away on the track, these don't!
http://s19.photobucket.com/albums/b1...t=DSCN0093.jpg
rear: http://s19.photobucket.com/albums/b1...t=DSCN0092.jpg
front: http://s19.photobucket.com/albums/b1...t=DSCN0094.jpg
Porterfield - Used front pads for '03-'05 , 50%, $25. part #:AP 815 R-4S
Great for track days.
http://s19.photobucket.com/albums/b1...t=DSCN0087.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0088.jpg
Hawk HPS (NEW) - Front Pads for '03-'05. $40 part #: HB268F.665 (D430/D815 HPS).
http://s19.photobucket.com/albums/b1...t=DSCN0079.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0081.jpg
Front Caliper seal kit; $5 I picked this up b/c the weather seal burned out on 1 of the calipers...
http://s19.photobucket.com/albums/b1...t=DSCN0082.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0084.jpg
http://s19.photobucket.com/albums/b1...t=DSCN0083.jpg
this is the only seal I used:
http://s19.photobucket.com/albums/b1...t=DSCN0086.jpg
thanks!!
Old Oct 7, 2008 | 08:58 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
bump for a nice guy! Gratz on your sale Peter! Is the new owner going to be around the forum?
Btw I'll take the valve stems Let me know when we can meet up!
Old Oct 7, 2008 | 09:33 AM
wasuber's Avatar
wasuber
dibs on the Sony and Kicker speakers! PM'd
Old Oct 7, 2008 | 09:39 AM
G35Soul's Avatar
G35Soul
PM'd
Old Oct 7, 2008 | 10:05 AM
drivesolo's Avatar
drivesolo
bump for good seller, awesome bud and phenominal driver.
Old Oct 7, 2008 | 10:53 AM
first350's Avatar
first350
updated w/ items for Alvin, Wasuber, G35Soul.
Old Oct 7, 2008 | 10:54 AM
wasuber's Avatar
wasuber
Thank you sir! I may pick up tomorrow. PM me your number if you get a chance or call me later tonight.
Old Oct 7, 2008 | 11:06 AM
Entaille's Avatar
Entaille
do you have any other pics of the zenclosure or are you able to link me to something with other pics? looks like you custom cut it up for your sub? just need some info on what I could buy to use with it, thanks man.
Old Oct 7, 2008 | 11:16 AM
first350's Avatar
first350
It's for a Kicker square soloBaric sub - I sold the sub, but still have the box.
http://s19.photobucket.com/albums/b1...t=DSC02226.jpg
http://s19.photobucket.com/albums/b1...t=DSC02228.jpg
http://s19.photobucket.com/albums/b1...t=DSC02242.jpg
http://s19.photobucket.com/albums/b1...t=DSC02250.jpg
Old Oct 7, 2008 | 11:24 AM
Alan_G's Avatar
Alan_G
Does the flywheel/clutch fit on a 06 Z?
Im intrested if your willing to ship
Old Oct 7, 2008 | 11:39 AM
Entaille's Avatar
Entaille
sweet, ill just have to replicate yourset up, that is a kick *** deal
can you hold it for me until thursday? I can pick it up then!
Old Oct 7, 2008 | 11:40 AM
first350's Avatar
first350
sounds good. I'll PM you w/ my info.
Old Oct 7, 2008 | 11:41 AM
first350's Avatar
first350
not sure...I can ship, but it'll cost a little more for my time.
Old Oct 7, 2008 | 12:16 PM
Alan_G's Avatar
Alan_G
Alright so how much do you want for it?
Old Oct 7, 2008 | 12:51 PM
first350's Avatar
first350
$160 + shipping.
Old Oct 7, 2008 | 01:53 PM
Mixturepinoy's Avatar
Mixturepinoy
Peter, can i get just the shocks and the rubber doo dads that go with them?
Old Oct 8, 2008 | 07:41 AM
first350's Avatar
first350
wheels didn't fit drive-solo's S14...they're up for sale!
Old Oct 8, 2008 | 07:50 AM
wasuber's Avatar
wasuber
If peter doesnt have any doo dads I have some and shocks if you need them dude
Old Oct 8, 2008 | 08:27 AM
Mixturepinoy
cool' i think after 93k they're starting to struggle big time. I don't want to put my springs on shocks that may end up dying soon...
Old Oct 8, 2008 | 08:33 AM
first350's Avatar
first350
PM sent
