MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Southern California (https://my350z.com/forum/southern-california-27/)
-   -   i'm buying Evo TT (https://my350z.com/forum/southern-california/418549-im-buying-evo-tt.html)
thomas'Z Feb 22, 2009 03:57 PM
i'm buying Evo TT
I am buying the Evo tt exhaust brand new for 1,250.00. does that sound like a good price?
thanks
zete350 Feb 22, 2009 04:38 PM
I have no idea if that price is good or not. But did u check with the vendors on this site? They seem to have the best pricing on everything.
FastZ33 Feb 22, 2009 05:23 PM
try and find it used bro
thomas'Z Feb 22, 2009 06:35 PM
why used? i want something still in the bubble wrap, i already have "hand me down" wheels
FastZ33 Feb 22, 2009 06:37 PM
ok but if ur gonna spend 1300 for an exhaust at least get the HKS
TheOtherRob Feb 22, 2009 06:50 PM
Do you have a turbo kit OP?
And that exhaust is discontinued if I remember correctly, so I suppose that price is fine. But if you don't have a turbo kit, why by a exhaust designed for turbo cars?
thomas'Z Feb 22, 2009 07:15 PM
its not discontinued, i'm working my way up to a turbo just getting other things first.
TheOtherRob Feb 22, 2009 07:17 PM
I believe that the Turbo TiC dual exhaust replaced this exhaust last year. Some vendors still have some left. But if your going to being doing a turbo install than this is a great idea. Good luck.
thomas'Z Feb 22, 2009 07:58 PM
i went to greddy its self and it is for sale still for 1,595.00
http://www.greddy.com/products/displ...&SubCategory=3
the 240sx, Rx8, Rsx, and the Civic Si are all discontinued tho.
gimpster621 Feb 22, 2009 08:14 PM
are you turboed? NA setups with evott's have been known to sometimes lose power
Jay'Z Feb 22, 2009 08:18 PM
NA is fail with the Evo TT....
thomas'Z Feb 22, 2009 08:36 PM
so basiclly putting this exhaust on im going to lose power, but its good with the greddy bolt on Turbo that i just happen to not have.
so i guess i should look up the Greddy Tic and see what that exhaust is all about.
aarantes Feb 22, 2009 08:36 PM
:werd: NA and Evo TT do not mix:dunno:
thomas'Z Feb 22, 2009 08:56 PM
ok so would i still loose power with the Evo tt if i had a MD 5/16 spacer, Intake, and Remapped Ecu?
TheOtherRob Feb 22, 2009 08:57 PM
The single TiC yes, the dual TiC no. The Evo TT is discontinued from what a vendor told me on here. The Dual TiC is the replacement for the Evo TT and should only be used for a turbo setup since it has larger piping. If you are going to add a turbo kit later on this would not be a bad investment now since you would have to replace the exhaust again once you went FI. But if you are going to have your car NA for a couple years before going FI, I would look into exhaust with small diameter piping to use for the time being.
TheOtherRob Feb 22, 2009 09:01 PM
To be completely honest, probably yes. Will it be enough to feel? Probably no. The cause for the loss in power is the larger diameter piping on the exhaust eliminating needed back pressure. Lets just say that you would be taking a step back and a step forward. The spacer would give you some extra power that the larger exhaust would take away... If you want more power NA, test pipes will yield more bang per buck than anything.
thomas'Z Feb 22, 2009 09:02 PM
ok well that sucks but i rather not loose any horses.. so ill stay away from exhaust for just a bit till i can go Fi and not worry about loosing any horses...... but arnt test pipes illegal or something?
TheOtherRob Feb 22, 2009 09:08 PM
Lets just say that you wouldn't gain as much if you went with a smaller diameter exhaust. But when you go FI, you will receive the benefits of having a bigger exhaust. I would say buy the Evo TT or the TiC Dual depending on the looks. They are the exact same size in regards to piping. The TiC Dual can be had for 999 shipped I believe, so that may be something to consider. This will save you money in the long run because when you go FI in a few months, you will already have a good exhaust for it. If you bought the Nismo exhaust now for example you would have to sell it and lose some money to switch over to a larger exhaust.
thomas'Z Feb 22, 2009 09:13 PM
yea makes sense, and they would compliment with the greddy turbos correct?
als does greddy have a Single Turbo set-up?
TheOtherRob Feb 22, 2009 09:15 PM
If you went with any twin turbo kit those exhausts would be a good choice. And no greddy does not make a single turbo kit. TN is one company that does off the top of my head.
