New Bilstein PSS10 Coilovers are Here!
Old Oct 27, 2008 | 08:58 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default New Bilstein PSS10 Coilovers are Here!
Just landed this morning guys and we've got 'em ready to go!
The new PSS10 is a step up from where the PSS9 left off. Adding an extra level of dampening adjustment (now 10 total clicks of adjustment front and rear), these units have monotube dampers, fully galvanized housings, and feature spring rates of 370 lbs front, and a progressive rear rate of 240-420 lbs rear.
The biggest change to the PSS10 vs the 9 is the adjustment **** - the new **** is much easier to use, with larger numbers. Since the size increased, it's now easier to feel the adjustment clicks as well. They also added an additional level of adjustment. Total span of adjustment between full stiff and full soft is approximately 30%. These are the ideal coilover for someone who wants the ability to adjust height and dampening, but who also demands a quiet, solid, european inspired ride (firm, but well controlled, without being rigid and unforgiving).
We are pricing them at $1895 shipped in the 48 states
To order, just give us a call at 631-863-3820
Old Oct 27, 2008 | 09:10 AM
blasian's Avatar
blasian
How would these compare to the V3s Adam?
Old Oct 27, 2008 | 09:13 AM
Z1 Performance
Former Sponsor
really is no way for me to answer that, they are a different kind of coilover for a different kind of customer and in 2 different price groups
Old Oct 27, 2008 | 09:14 AM
blasian's Avatar
blasian
Gotcha. I'll just stick to what you've told me already
Old Oct 27, 2008 | 09:38 AM
jubes's Avatar
jubes
Price shipped to 91326
Old Oct 27, 2008 | 10:15 AM
Z1 Performance
Former Sponsor
are people so conditioned to pricing not being posted?
look at the first post, it's there
Old Oct 27, 2008 | 10:17 AM
blasian's Avatar
blasian
You know how it is sometimes, I almost passed it up at first glance.
Bump for an awesome price
Old Oct 28, 2008 | 05:29 PM
Sea Bass's Avatar
Sea Bass
Price shipped into Vancouver, BC, Canada, at V6Z 2S6. I really have my heart set on some Bilsteins.
Old Oct 28, 2008 | 06:33 PM
Z1 Performance
Former Sponsor
[QUOTE=Sea Bass;6486973]Price shipped into Vancouver, BC, Canada, at V6Z 2S6. I really have my heart set on some
Pmd
Old Oct 28, 2008 | 08:00 PM
tired's Avatar
tired
How do these spring rates compare to other dampers for the Z?
Old Oct 28, 2008 | 08:05 PM
Z1 Performance
Former Sponsor
Spring rates are listed, so you're free to compare them to whomever else you want. Just realize that it will tell you much of anything quite honestly - spring rate comparisons are only truly meaningful when they are on the same damper. Comparing the rates of one manufacturer to another when each uses their own damper, valving specs, etc, is pretty much worthless
Old Oct 28, 2008 | 08:17 PM
geomark's Avatar
geomark
How do you adjust these exactly? Is there a seperate **** for the front and rear or is adjustment only on the front. Also, is it compatible with the EDC system? If so, how much with EDC? Thx
Old Oct 28, 2008 | 08:23 PM
Z1 Performance
Former Sponsor
the dampening adjustments are at the bottom of the rear each damper and the top of the front - each one has it's own adjustment ****
there is no electronic adjustment offered nor planned according to Bilstein
Old Oct 28, 2008 | 08:52 PM
Sea Bass's Avatar
Sea Bass
Price would be $1619 shipped to Canada
Ohhhhh baby! Now I can only hope the Canadian dollar shoots back up (we've gone down 20 cents, 20 cents, in about 2 months). I want these.
Old Oct 29, 2008 | 03:16 AM
Diesel350's Avatar
Diesel350
Oooh nice I want. How low can these go?
Old Oct 29, 2008 | 05:18 AM
Z1 Performance
Former Sponsor
they allow for approximately a 1.5 inch drop up front and back. If you want to go lower in the rear you can remove one of the lower spring locks and gain another ~3-4 mm
Old Nov 1, 2008 | 05:22 AM
Z1 Performance
Former Sponsor
ttt
Old Nov 3, 2008 | 07:41 PM
Z1 Performance
Former Sponsor
bump it up...4 sets left
Old Nov 4, 2008 | 07:22 AM
Gsedan35's Avatar
Gsedan35
the dampening adjustments are at the bottom of each damper - each one has it's own adjustment ****
So how did they move the adjustment to the bottom on the fronts? Did they make slit's or window's above the lower mouting leg's to view and adjust a dial or is it a dial on the side of the shock body above the lower mounts legs like how Koni DA shocks adjust compression?
Old Nov 4, 2008 | 04:53 PM
Diesel350's Avatar
Diesel350
Adam,
What are the main differences between these and the BC Racing Coilovers?
