HR's rev limiter
Old Oct 3, 2007 | 01:38 PM
VitViper's Avatar
VitViper
Originally Posted by warmmilk
when shifting at the redline, the 07 falls out of the power band a little bit, even raising the rev limit a few hundred rpm's would help cause it would put u back in a better spot in our powerband, just like shariff said
On the HR that's only really the case when going into 2nd and not even a bother with the 4.083 gears. going from 1st to 2nd you drop down to 4600 rpm, 2nd to 3rd puts you at 5300 which is right at the start of the kick *** 07 top end. The rest of the shifts you lose about 1500-1600rpms putting you in the meat of the juicy pull, bwhaha.
shorter gears like vitviper has help to, but i'm just a fan of long gears, cant' help myself, there is something about going into second at 55 and not having to shift instantly
You should come down to like portland/vancouver and take my car for a spin. I sometimes do miss being able to downshift to 2nd at 55 and nailing it... until I ease into the throttle and feel how much stronger the car is
Old Oct 3, 2007 | 05:27 PM
warmmilk's Avatar
warmmilk
^ 2nd and somewhat of third, and 3rd is as far as i get at the drag strip with the stock gears, which i have no intentions of changing
i don't konw, portland is pretty far just to take a spin in a car, but then again, i do wanna try out those 4.083 gears
Old Oct 3, 2007 | 05:42 PM
VitViper's Avatar
VitViper
I was always shifting into 4th right before the end. Would of bounced rev limiter in 3rd if I hadn't.
I drove 4 hours to get wasted with old friends, then drove back 24 hours after I came up. lol
Old Oct 3, 2007 | 06:07 PM
warmmilk's Avatar
warmmilk
oh yeah, i forgot, show's how long its been since i was at the track
Old Oct 22, 2007 | 08:33 AM
504Z07's Avatar
504Z07
Originally Posted by Skorch
So does the HR make its peak power in the 1st 2nd and 3rd gears at 7500 or lower? And if it is indeed at 7500, would there be a benefit to increase the rev limiter to say... 7600 to compensate for imperfect shifts and decrease the chances of hitting the rev limiter?
The HR makes full horsepower at 6400 rpm. . .i've always had better grip and better 1/4 times when shifting at 6400. . .anytime i went past 6400 it just spun halfway through 2nd. . .unless you let off the gas, shift, back on the gas. . .but you would still be losing precious seconds. . .
Old Oct 22, 2007 | 11:21 AM
itsjiggajames's Avatar
itsjiggajames
you shift at 6400 into second? Odd, I feel the car is much faster shifting at 7500rpm... a little wheel spin into second but much harder too.
Old Oct 23, 2007 | 12:23 PM
07-Zman's Avatar
07-Zman
Your smoking dope!
