Hr serpentine belt without ac compressor.
Hoping some hr track guys will chime in. Pulling my ac system next week and want to confirm belt length and new routing needed to maintain optimal tension. Only found one post stating 50.75inch belt routed directly from 8 pulley to 4 crank (skip pulley 5 and compressor 6)
Much appreciated. https://cimg9.ibsrv.net/gimg/my350z....abec3f627c.jpg |
Damn no a/c ... that's gangsta!
Sorry bro no clue. |
You may have some real problems with that. The most obvious is the amount of contact between the belt and the crank pulley - it will be far less with the new routing, and there may be some slipping because of that. The second issue is that the tensioned will also have a much shorter run of bely to act on, and it may not work properly.
Can't help you with the length. Get a piece of string and measure it. |
What year is your car? I did belts on my 06 last weekend, dedicated a/c belt separate from serpentine. Both run on grooved pulleys.
Originally Posted by jhc
(Post 10636267)
Originally Posted by dcains
(Post 10636416)
Your '06 doesn't have the HR engine.
Bump. Ac delete on track cars?
Bump wondering also.
I'm also interested as i think i will remove my AC one day or another...
DE > HR when it comes to AC delete. My DE self deleted its AC belt a few times....in the summer.
OP the belt routing you are looking into won't work. Dcains called it. The tensioner will just hit full extension and the belt will be limp. Idler 6 is crucial for the tensioner to work. Your best bet may bey to fab a dummy pulley where the AC used to go. |
By pass airconditioner
Originally Posted by CKdevil
(Post 10636222)
