MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Wheels & Tires (https://my350z.com/forum/wheels-and-tires-60/)
-   -   Which Volk center caps for RE30's? (Volk350Z!) (https://my350z.com/forum/wheels-and-tires/256776-which-volk-center-caps-for-re30s-volk350z.html)
mthreat Mar 16, 2007 09:29 PM
I just got some Volk RE30's and ordered these center caps:
http://www.injectedperformance.com/V...t.aspx?ID=3857
http://www.injectedperformance.com/I.../Med-3857a.jpg
and while they fit fine, they don't seem to be very tight in the wheel. Are these the correct center caps for RE30s, and if not, which center caps are the correct ones? Thanks
Nitrouz Mar 16, 2007 09:32 PM
not sure about RE's, but I'm sure those are the centercaps for TE's (time attacks).
A good bet would be to PM "volk350z".
JDMFairladyZ33 Mar 16, 2007 09:33 PM
Did you try putting a rag or something over and give them a good wack with a rubber mallet? My GTS centers didn't go on well with me pushing on them. I got them to fit nice and snug after I tried ^.
mthreat Mar 16, 2007 09:45 PM
They went in okay, and "snapped" into place (didn't really make a snap sound though!). But they just seem like aren't very tight... compared to my GT-C center caps. I'll double check just to be certain.
JDMFairladyZ33 Mar 16, 2007 09:49 PM
Yeah I know at you mean. The rubber lining around the cap just kind of gets pushed in. As long as the cap is straight all around you should be alright. I was paranoid for like the first month and kept checking them. They never moved or popped up. You should be okay.
Volk350Z Mar 17, 2007 12:05 AM
yup.. those center cap will fit... just make sure you use the right o ring..
Nitrouz Mar 17, 2007 12:09 AM
so that's what you do to make it stay up...lol...
mthreat Mar 17, 2007 12:42 AM
Thanks for the fast reply Brian! Which is the correct O-ring? Here's a photo of exactly what I received in each package of 2 center caps:
http://www.zeroslope.com/350z/volk-centercaps.jpg
So it looks like they came with 1 extra O-ring per center cap? Or do I need to change out the O-ring for different wheels? The little instruction manual is in Japanese, which I can't read! Here it is, zoomed up:
http://www.zeroslope.com/350z/center...structions.jpg
Can someone translate? thanks!
Volk350Z Mar 17, 2007 10:54 AM
I just normally use the thicker o ring with im running it on RE or CE wheels
mthreat Mar 17, 2007 11:28 PM
Ok..I just swapped out the O-ring with the thicker ones that came with the center caps. Now it fits in the wheel MUCH better, now it feels secure. Before I could pull the center cap out by just pulling on the front (face) side of the rim... now i have to push fairly hard from the inside to pop it out. Thanks
Now I'm curious about the hub rings that came with the wheel.. but I posted that question in another thread
azula Mar 18, 2007 06:10 AM
WOW....i didn't know center caps were so expensive, lol.
