Can't decide between 15mm and 20mm spacer for the front- Pics inside
Old May 12, 2010 | 07:15 PM
phreaktor's Avatar
phreaktor
Design Engineer
Lightbulb Can't decide between 15mm and 20mm spacer for the front- Pics inside
My rears are perfect without spacers, but I'm not happy with the front. 19x8.5 or 9 with a 245/35/19. I measured from the tire right to the edge of the fenders and it is exactly 20mm. My tires are square on the rim and not stretched or past the lip.
What I am wondering is, will my tires rub at stock height if it is totally flush with the fender? Do people actually roll the front fenders or not? I will be having the rears rolled next week.
One other issue I have since swapping my stockers is that my car seems to want to "wobble" in the rear almost as if the suspension is on the x axis rather than the y axis when I go over bumps. It's more noticable at highway speed. Rears are 19x10 295/30/19. The are DPEs so I do not know the offsets. Is this because of the width difference between front and rear? Is it bumpsteer?
Thanks
Attached Thumbnails Can't decide between 15mm and 20mm spacer for the front-  Pics inside-cimg2869.jpg   Can't decide between 15mm and 20mm spacer for the front-  Pics inside-cimg2872.jpg   Can't decide between 15mm and 20mm spacer for the front-  Pics inside-cimg2870.jpg   Can't decide between 15mm and 20mm spacer for the front-  Pics inside-cimg2871.jpg
Old May 12, 2010 | 07:18 PM
phreaktor's Avatar
phreaktor
Design Engineer
Rear:
Old May 12, 2010 | 08:23 PM
mgrotel's Avatar
mgrotel
drop it
Old May 12, 2010 | 09:00 PM
phreaktor's Avatar
phreaktor
Design Engineer
Thanks for the tip, but boost and paint are my priority right now.
Old May 12, 2010 | 09:03 PM
terrasmak's Avatar
I would do 15, to be totally flush you need camber and some stretch.
Old May 12, 2010 | 09:18 PM
User 42426's Avatar
User 42426
paint?? isnt your car already a custom paint job?
Old May 12, 2010 | 09:32 PM
phreaktor's Avatar
phreaktor
Design Engineer
Yea, but I had a mishap a couple weeks ago and my front end is effed up. Not to mention a nice dent over my right read quarter....
Old May 12, 2010 | 09:37 PM
sdZ33's Avatar
sdZ33
I had a 20x8.5 +5(+25 with a 20mm spacer) with a 245/35/20 and it didn't rub... Before using the 20mm spacer I had a 25mm spacer and it rubbed... And I was lowered 1"... I know you have 19's but I hope some of this info helps... GL
Old May 13, 2010 | 04:17 AM
3m wol8's Avatar
3m wol8
my 19x8.5 +7 has a 245/35/19 on it and it doesn't rub.. the front fenders cannot be rolled fyi.. i'm dropped on Hotchkis springs and have had zero issues... i'm running -1.2 degrees camber in the front also
Old May 13, 2010 | 07:33 AM
epidemic007's Avatar
epidemic007
Originally Posted by mgrotel
drop it
like its hotttttttttt
Old May 13, 2010 | 02:42 PM
phreaktor's Avatar
phreaktor
Design Engineer
Pics of your car? I don't want to have to add control arms...
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
