MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Wheels & Tires (https://my350z.com/forum/wheels-and-tires-60/)
-   -   Enkei RP01's wheels? (https://my350z.com/forum/wheels-and-tires/505104-enkei-rp01s-wheels.html)
huanandonly Oct 31, 2010 10:09 PM
Enkei PF01's wheels?
...i wanted to get opinions on these wheels... Enkei PF01's. Are they dependable?...No issues?
I have a stock 2007 Z right now and I am planning on getting these wheels but I need to know if they will fit ok with the specs that I am getting from TireRack.com. I plan on keeping them 18's and NOT lowering my car in any way and NOT rolling the fender also. Here is what is showing on TireRack.com:
FRONT:
18 x 8.5
Offset: 30mm
Backspacing: 5.90"
Bolt Pattern: 5-114
Rec. Tire Size:225/45-18
BACK:
18 x 9
Offset: 35mm
Backspacing: 6.33"
Bolt Pattern: 5-114
Rec. Tire Size:245/45-18
** I don't need the wheels to be hella flush, but are those offsets all right...or will the wheels look totally sunken in?... Any info would be great. Thanks!
huanandonly Oct 31, 2010 10:15 PM
Sorry...i meant, Enkei PF01 wheels
lemmiwinkz Oct 31, 2010 10:34 PM
pretty much same as stock just extended 1/4" on each side of the wheel because they are about the same offset as stock. so not to much more aggressive than what you have now. not sure how aggressive you wanted but if you wanted more aggressive this probably wont be enough. you should not have any issues with rubbing so you wouldn't need to roll your fenders. you could probably go another 25mm offset before it rubbed with that size wheel and tire. just a guess though
singh Nov 1, 2010 11:46 AM
i would just stick with stock wheels if you are gonna stay with the weak offsets
terrasmak Nov 1, 2010 12:45 PM
It will work , but i would really pick something different.
davidv Nov 1, 2010 01:53 PM
What happened to all these wheels?
https://my350z.com/forum/wheels-and-...need-help.html
https://my350z.com/forum/wheels-and-...8-x-9-5-a.html
https://my350z.com/forum/wheels-and-...ompatible.html
https://my350z.com/forum/wheels-and-...it-on-a-z.html
huanandonly Nov 1, 2010 02:56 PM
Davidv....like everything else in my life, I can't make up my mind! grrrrr.... the Lumarai's and Five:AD S5:F are a bit too "heavy" for my tastes....eventho the Five:AD S5:F are really nice ...the search continues
davidv Nov 1, 2010 03:39 PM
http://i206.photobucket.com/albums/b...el1/weds09.jpg
ha ha
I wanted a wheel that weighed less than 20 pounds. Budget was $900/4. Took me 3 years to find the right wheel.
huanandonly Nov 1, 2010 03:56 PM
Oh dang, ...i didn't even think about Weds... those SA 70's are really nice.... thanks! (this is why the search always continues) lmao
davidv Nov 1, 2010 04:12 PM
http://i206.photobucket.com/albums/b.../price1101.gif
For weight and price this has always been a popular wheel. Value is tough to beat.
Waiz Nov 1, 2010 04:14 PM
Enkei or used Nismo LMGT4's are a great option if you want a lightweight wheel that's a good value.
Rather than aimlessly making threads I suggest you attend some meets to see different wheels for yourself and decide from there.
Ztouring04 Nov 1, 2010 04:46 PM
I love my enkeis...but i would deff go wider.. heres a pic of mine 18x9.5 18x10.5 +15
http://img59.imageshack.us/img59/8043/enkei710009.jpg
http://img823.imageshack.us/img823/4671/enkei710013.jpg
huanandonly Nov 1, 2010 05:27 PM
NOICE!!... those are WIDE...looks great. Yah, Waizzz...i think going to meets is a good call....there's nothing like seeing the wheels mounted on the rides in person....thanks for all the suggestions.
scotts300 Nov 2, 2010 08:23 AM
If you are going 8.5, might as well buy the set of 18x8.5x4 stockers that I mentioned to you. :)
Otherwise go 18x9 or 18x9.5 all around, even 18x10.
