Wheels / tires compatible??
Old Aug 26, 2010 | 12:08 AM
huanandonly's Avatar
huanandonly
Default Wheels / tires compatible??
I am planning to pick up some Five:AD S5:F with these specs below:
FRONT 19" x 8.5 Offset +20 PCD 5x4.5
REAR 19" x 9.5 Offset +25 PCD 5x4.5
Do I have it correct?....And will these work with these tires?
FRONT 245/35/19
REAR 275/35/19
***Note: I do NOT plan to lower my Z at all... will this look ok?
or should i go with another tire specs?
'Newbie here...so any info/suggestion would be great! thanks!!
Old Aug 26, 2010 | 01:05 AM
terrasmak's Avatar
I could be wrong, but you will have a hard time installing them on a Z with that lug patern.
Don't they offer a 10.5? If so i would throw 10.5 in the rear and 9.5 for the front.
Edit, i looked and yes they offer 10.5 rears, and BTW the tire sizes you selected are perfect, same height as stock tires just wider.
Old Aug 26, 2010 | 01:10 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
^+1... you mean 5x114.3 PCD right? 35's may look too skinny for a 19 though w/o being lowered.. i'm not 100% sure.
Old Aug 26, 2010 | 04:38 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
5x4.5 = 5x114.3 just different units of measurement.
Old Aug 26, 2010 | 04:56 AM
370Z tires are:
Bridgestone Potenza RE050A, 245/40R19 / 275 /35R19
So you will be running the same size except front 35 instead of 40 series. This will be perfect.
Old Aug 26, 2010 | 06:07 AM
scotts300's Avatar
scotts300
FRONT 245/35/19
REAR 275/35/19
All looks good.
4.5 * 25/4 = 114.3.
I agree about the 9.5 front and 10.5 rear, if at all feasible and if it makes the wheel look "better".
Old Aug 26, 2010 | 06:18 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Everything looks good except wheel (rim) widths, so change to this:
9.5" fronts
10.5" rears
Try to keep the offsets for both around et.20.
Old Aug 26, 2010 | 07:59 AM
Flo-ridaZ33
Gotcha.. thanks
Old Aug 26, 2010 | 10:49 AM
huanandonly
wait... so if i run 9.5 in front and.....10.5 in the back....what tire sizes would be correct?...and ideal offset?
Old Aug 26, 2010 | 11:35 AM
hwcustoms's Avatar
hwcustoms
255/35 and 285/35 and a low +20's offset will be good.
Old Aug 26, 2010 | 11:37 AM
Kuhan's Avatar
Kuhan
edit: ^beats me
245/35 front and 275/35 rear
255/35 front and 285/35 rear (more sidewall = more circumference)
ideal offsets would be around 20mm for normal flush look on 9.5" and 10.5"
Old Aug 26, 2010 | 12:13 PM
huanandonly
ok...thanks for all the info guys!
Obadabot
Jun 18, 2023 11:31 PM
