20" Axis Se7en Mods
Just wondering if anyone here that has these wheels in the 20 x 9 front and 20 x 10 rear had any fitment issues or if they just bolted right on with no probs.
Thanks. :) |
Hey there Jeffrey,
I have them on my base 350z. They bolted right on AFTER I removed the guide bolts from the rotors. I also picked up a pair of spacers for them and stuck them on the rear rather than the front. If you are running brembo's then you may want to consider some 15mm spacers. I purchased the entire set from Wheel Studio in Cali as a huge package for ~2700 bucks. I highly recommend the wheels! But you really shouldnt run into any problems with fitment, etc... --justin |
fitment?
if you had to use spacers how can you say they fit? I always took spacers = no buying the correct offset.
Just wondering |
Hey, thanks for the response Juztin.
Did you need the spacers or was it to make the wheels stick out a little more just for appearence? I may be ordering these this weekend and I just want to know if I need anything special or not. Thanks. :) |
