Are Track or Nismo's lighter?
Does anyone know if the Track model wheels are lighter or heavier than the Nismo's? Or possibly the same... Thanks!
hmmmm good question, i think i don't know
Thanks!
i believe they're the same dry weight... but on a car, the track rays will be "lighter" because there is less rotational mass (18x8 and 18x8.5 as opposed to 18x8.5 and 18x9.5 = more mass at the furthest part of the rim)
Track 18":
Super-light Alum Alloy F-18x8 18.188lbs R-18x8.5 18.629lbs cannot find info on the nismo's but i remember that they weigh 18 lbs plus change also. |
I remember seeing the spec for Nismos a long while ago... if I'm right, the Nismos are 'a bit' heavier than the track Rays... but almost the same
Originally posted by samw1978 I remember seeing the spec for Nismos a long while ago... if I'm right, the Nismos are 'a bit' heavier than the track Rays... but almost the same |
Originally posted by Zlife-000 Question...aren't they both made from Ray's? |
nismo's front and rear are 0.x kg heavier .
yes they are both made by Rays...
track at 18.2/18.6lbs where the Nismo is at 18.4/19 or something like that? OMG! my bad memory... :( |
Thanks for the info. I guess either way I go, it will be better off than my stock Touring rims. Of course I think the Nismo's win out on style.
The Nismo are lighter....
in the front just by a hair and heavier in the rear just by a hair...however, the Nismos will allow you to use 275 width rubber in the rear, the tracks won't. Go Nismo for sure.
I definitely want fatter tires... especially after my Vortech is installed!!!
nismos are 18lbs front, 18.8lbs rears. not sure what my tracks were. not as pretty????:D
We have a thread about this already.
https://my350z.com/forum/showthread....threadid=73802 nismo's are slightly heavier. I still like them more tho... of course, I am biased. nismo LM-GT4 8.2kg (f) 8.6kg (r) Rays' Track wheels 8.1kg (f) 8.3kg (r) |
| All times are GMT -8. The time now is 03:14 PM. |
