any problems here?
Old May 26, 2007 | 07:27 AM
ke0ki2k's Avatar
ke0ki2k
Default any problems here?
will 18x9.5 inch LMGT4's fit front and rear with 265/35 or 265/40? I have no TCS of VDC (base coupe) so removing the stagger wont screw it up, im just looking for maximum traction with minimum weight. plus rotating will save me some $$ later on. . thx in advance.
Old May 26, 2007 | 08:09 AM
DavesZ#3's Avatar
DavesZ#3
It shouldn't be a problem. I'm running 255/35/19 on the street and 265/35/18 for autocrossing and have no clearance problems. I've seen where people run 275 and 285 tires up front in autocrossing too.
Old May 26, 2007 | 08:11 AM
This is a comparison between the OEM front wheel and the one that you are considering. What do you think of the inner clearance?
Old May 26, 2007 | 08:14 AM
ke0ki2k's Avatar
ke0ki2k
are the nismos 25MM offset?
Old May 26, 2007 | 08:19 AM
350Zenophile's Avatar
350Zenophile
You'll be fine on clearance since others run this same combo with stock and aftermarket suspension. However, something no-one seems to really mention is that high-speed stability (80mph+) can be negatively affected.
Old May 26, 2007 | 08:24 AM
ke0ki2k's Avatar
ke0ki2k
how would it be negatively affected with more grip up front?
Old May 26, 2007 | 08:37 AM
Yes. Reference: http://www.courtesyparts.com/Merchan...ode=4030S-18SR
Old May 26, 2007 | 09:30 AM
350Zenophile
Oversteer can make the car feel unstable at high speeds. SCC just changed the tires back to a staggered fitment on their famed 1G 350Z project car because of this.
Old May 26, 2007 | 10:53 AM
ke0ki2k's Avatar
ke0ki2k
stiffer rear sway would fix that problem wouldnt it? and with a 25mm offset will 275/35's fit up front?
Old May 26, 2007 | 12:45 PM
350Zenophile
Not to got to off topic here but I plan on writing into them to ask the same question. I know they are running adjustable Hotchkis sways so why couldn't they have just made an adjustment there to dial out some understeer?
Old May 26, 2007 | 02:36 PM
ke0ki2k's Avatar
ke0ki2k
yeah, for real. But, does anyone know FOR SURE that no matter HOW hard you corner, 275/35's will NOT bottom out on the suspension or the fender up FRONT?
Old May 26, 2007 | 03:11 PM
Korki Buchek's Avatar
Korki Buchek
Maybe they've already adjusted the hotchkis rear sway?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
