Anyone know how to manualy open soft top?
Old 03-31-2007, 03:12 PM
David2673
David2673's Avatar
Default Anyone know how to manualy open soft top?
Can anyone help me out. I was having a problem last fall with my soft top. It wouldn't close properly. So I followed the manual closing proceedure in the manual. Now I cannot get it open to work on it. The fifth bow (back section of soft top) is locked into the trunk and I would like to know if there is a quick and easy way to unlock it so I can fold the 5th bow forward and then open the hard cover. Any insight would be greatly appreciated.
Thank you in advance
David
Old 03-31-2007, 03:16 PM
charlie_rdstr_Z
charlie_rdstr_Z's Avatar
Ouch. Let the dealer handle it since it is closed. It will be worse off if you can't close it from snow and thieves.
Old 03-31-2007, 03:20 PM
David2673
David2673's Avatar
The dealer will be my last resort as there is no warranty on my z. I called them last week and the soft top controller unit is around $1200.00 just for the part. I want to try and figure out the problem myself to avoid being raped at the dealer.
David
Old 04-03-2007, 01:13 PM
Mang
Mang's Avatar
Hmm understand your problem, normally manual closing procedure is fully described, just to close the top in an emergency case.
But how to open it after it has been closed manually, is not explained.
I will check on my car how to unlatch the 5th bow manually.
Old 04-03-2007, 01:39 PM
Mang
Mang's Avatar
I have check both car and the handbook.
Once manual locked the 5th bow cannot openend. The manual mention to remove the telescopic dampers of the rear roof part. And have the rear part of the folding roof resting on the cover by its weight, and not to lock it.
There must be somewhere a hidden manual unlatch cable for the 5th bow.
Keep me informed
Old 04-07-2007, 09:13 AM
David2673
David2673's Avatar
Thanks for trying to help Mang,
I was at the delaers a couple of days ago and they were stumped. One idiot actually told me that it was impossible to do. He actually said that once down it can NEVER be opened. So according to him I am stuck with a non-converting convertable for the rest of its life. I think not. I am going out to work on it right now and try to fugure this damn thing out. Oh yeah, the other guy at the dealership called the nisssan tech line and they need a few days to figure it out. They will get back to me. Wish me luck or I will have to use an exacto knife to open it and duct tape to close it every time.
David
Old 04-14-2007, 11:56 AM
David2673
David2673's Avatar
I finally go the top to open manually, Not an easy task. If anyone ever needs to know how to do it lemme know.
David
Rose7117 (03-14-2021)
Old 04-14-2007, 03:12 PM
Mang
Mang's Avatar
Hi David,
I really checked every written item on this one but couldn't find the answer.
As I wrote before the Nissan emergency procedure is not to latch the top.
Did you activate the unlatch mechanism by external 12 Volt trough the wiring loom ? Thats what in my mind to do so.
But you have to find which wire and routing....................
Let me know
Old 04-14-2007, 04:17 PM
David2673
David2673's Avatar
Hi Mang.
I actually had to remove the climate control panel, to remove the panel between the seats, and remove the lower door trim, to remove panel covering the subwoofer, to remove both rear side trim pieces to remove the panel covering the speakers to remove the real storage bin to access the rear of teh vehicle. Once I gained access I had to pull down the soft top storage area finishing cover to access the inspection panel under teh 5th bow of the soft top. After opening the inspection panel all it took was a pull of the release cable to unlock the 5th bow. Simple. Now that I have it open I just have to figure out why the top will not work on its own. Wish me luck.
Have a good day.
David
Old 04-23-2007, 08:31 PM
koolboyztn
koolboyztn's Avatar
did you installed any alarm recently ? what happended to me is that after i got mine installed the viper remote start, the top wont open..but after couples hours test one by one they found out that they need to add he relay to igition wire cable, i dont know about the detail but that what i been told.
Old 12-02-2012, 07:47 AM
bcb06gt
bcb06gt's Avatar
Bringing this thread back. My issue is on my sister-in-law's (SIL) car. Top would not close a few months ago. 5th bow seemed to be the issue. Followed the owner's manual to close the top (which includes disconnecting a connector on each side). Top got closed and 5th bow motor removed. I followed the 5th bow motor repair guide on the forum.
Yesterday she brought the car over to install the 5th bow motor. Once installed, I tried the top. The windows never lowered and only noise was a "click" from the center rear area. I didn't remember about the connectors. How does one access the connectors when the top is up? How can the top be operated manually to reach the connectors?
Thanks in advance.
Old 03-27-2015, 11:32 AM
DeusExMaxima
DeusExMaxima's Avatar
Reviving this old thread again - This is exactly what I need to know too. I put the top up manually by disconnecting the two grey connectors and disconnecting the two upper rods according to the service manual. How do you get access to reconnect everything?
Old 03-30-2015, 01:19 PM
DeusExMaxima
Anyone?
Old 01-07-2019, 04:41 PM
Dlwarre
Dlwarre's Avatar
David this is a very old thread but can you remember what needs to be done to open it?
Old 01-07-2019, 05:07 PM
travlee
Master
travlee's Avatar
Received 9,059 Likes on 6,523 Posts
he hasn't logged in going on 7 years
Old 01-07-2019, 05:10 PM
Dlwarre
Dlwarre's Avatar
thank you
Old 01-07-2019, 05:11 PM
Dlwarre
Dlwarre's Avatar
Do you know if there is a manual for the touring model 350Z
Old 01-08-2019, 05:45 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,067 Likes on 755 Posts
Yes - what year do you need?
Old 01-08-2019, 07:52 AM
Dlwarre
Dlwarre's Avatar
Thank you sir, I am trying to figure out how to get to the 5th bow motor. my top will not go down. the process begins by moving the passenger seat forward while rolling down the windows, but then nothing after. The top is unlatched as i can pick it up from the back and drop down to re engage.
I am assuming I need to replace that motor.
Old 03-14-2021, 01:55 PM
Rose7117
Rose7117's Avatar
Default Help with manually opening top
Hi David! Was wondering if you could share how you manually opened your top. My windows roll down but wont go further than that. I hear clicking but nothing activates. Thank you so much. Aloha from Maui!
QUOTE=David2673;3606200]I finally go the top to open manually, Not an easy task. If anyone ever needs to know how to do it lemme know.
David[/QUOTE
Quick Reply: Anyone know how to manualy open soft top?
