Project: Nismo roadster
Old 01-19-2015, 03:20 AM
  #81
che69velle
che69velle's Avatar
One of the removable hard tops would make your car awesome IMO
http://autoplicity.com/521002-seibon...nXVRoCeYjw_wcB
Old 01-24-2015, 07:20 PM
  #82
DeusExMaxima
DeusExMaxima's Avatar
I think I need new shocks. my first thought is Tokico d spec because they are adjustable but seem like they would be good for the street also. There are tons of threads and information on shock absorbers and everyone has an opinion but for my application where I do not want to lower the car and just want a slightly firmer ride then stock, similar to the nismo. I'd like your suggestions
Old 01-25-2015, 11:16 AM
  #83
travlee
Master
travlee's Avatar
Received 9,060 Likes on 6,523 Posts
i had them on my Z, i loved em. not sure how you would adjust the backs because i am sure a vert is different, with my coupe i had the extenders up under the rear covers for the strut bar
Old 01-29-2015, 02:10 PM
  #84
DeusExMaxima
Maybe Ill just go with the non-adjustable Tokico HP. I thought about Tein springs to lower it .5" but Im already rubbing that lovely Nismo nose on the ground sometimes, so Ill stay with stock springs
Old 01-30-2015, 03:15 PM
  #85
DeusExMaxima
I decided to cave in a buy the Nismo lower side skirts from Courtesy Nissan in Texas. The cost shipped will be $721.31.
Here is my reasoning: I have rare and expensive OEM front and rear Nismo bumpers (and some interior pieces). If I buy the replicas and paint them, it will cost $500 in the parts plus paint (paint is expensive in case you didnt know). Then....if I find used OEM side skirts, that will be another $500 in parts and paint if the seller is reasonable. If I buy the OEM pieces now and paint them it will be about $900 and it will be done and over with and I will have all an all OEM nismo body kit.
I should receive them in about 12-14 days.
Im also considering buying some black leather with red stitching from redline and covering the door panel arm rests, center arm rest, and handbrake handle and shifter. The Nismo has red stiching and black leather on the door panels but they are rare and expensive.
Old 01-30-2015, 05:24 PM
  #86
travlee
Master
travlee's Avatar
dont ya wish you were in texas? i live 20 min from them, and work 5 min away from them
Old 01-31-2015, 12:03 AM
  #87
DeusExMaxima
Yes I do.. The skirts will be in Texas from Tennessee by Thursday and then it takes another 3 to 4 business days to get to So Cal. In the mean time, ill buy more super black paint and clear coat and get ready for their arrival. The weather that weekend will be nice for painting (75 to 80 degrees)
Old 02-04-2015, 02:52 PM
  #88
DeusExMaxima
Waiting for those skirts!!!!
Old 02-05-2015, 10:30 AM
  #89
DeusExMaxima
While Im waiting to complete my OEM Nismo body kit, Im looking into updating my interior to the 06+ center console.
Old 02-06-2015, 10:38 AM
  #90
DeusExMaxima
I have some OEM Nismo door panels on their way to me. I should get them next week. I had a weird dream about the Nismo side skirts. I dreamed that I got them early, but they were way too short and one of them was broken in about 3 or 4 pieces. I was trying to figure out how to glue them together to I could mount them on the car, even though they were about 3 feet too short!
Old 02-08-2015, 11:33 AM
  #91
DeusExMaxima
I acquired a barely used shift **** from a 2012 GTR. Its much nicer looking than the giant OEM ****. The original **** comes off very very easily by removing the lower trim ring from the **** and pulling out the clip. the GTR **** has the same pieces. It has a lower trim piece that pops off and a similar looking clip that holds the **** to the shaft. The **** slipped on easily and clip into place but the button on the top did not activate the lever. I will need to get another small plastic piece that sits on top of the shaft and modify it in order to have it slip into a small hole inside the GTR **** and allow the button at the top of the **** to activate the shifter.
Original ****:
GTR ****
the GTR **** is 1 inch lower overall. But the bottom of it sits higher up from the console. There are two choices to remedy this. The first choice would be to cut down the shaft to the same level where the GTR **** sits in the actual original car. This choice eliminates the possibility of using the original **** again. The second choice is to install a leather boot which goes from the **** and surrounds the console. This gives it a nice finished look and also gives the illusion that it is a manual transmission if that is important enough. Many cars today use a leather boot to make it look like it is a manual transmission.
I will go with the second choice and get a booth at fits around the console. I will also fabricate some kind of plastic piece that will go over the shaft and will go into the GTR **** to allow it to activate the transmission
Old 02-09-2015, 02:27 PM
  #92
DeusExMaxima
I did a quick MSPaint to see what the shifter would look like when its shortened:
Old 02-10-2015, 07:04 AM
  #93
myork
myork's Avatar
You lose all your interwebz until you wipe all the dust off your radio before posting pics
Old 02-10-2015, 08:15 AM
  #94
che69velle
che69velle's Avatar
Good god that's a dirty waterfall and console.
Old 02-10-2015, 05:58 PM
  #95
DeusExMaxima
I figured out the **** situation. Also wiped my waterfall:
Old 02-10-2015, 06:04 PM
  #96
che69velle
che69velle's Avatar
That looks good.
Old 02-11-2015, 02:27 PM
  #97
GreyZ
GreyZ's Avatar
It looks pretty good! As time goes on, I would suggest some wheel spacers. and a different wing. Sell that one and get something like the v3 (that belongs with that kit) or a superleggera rep wing. Possibly nismo suspension if you can find a used set
Old 02-11-2015, 09:18 PM
  #98
DeusExMaxima
the problem is that the larger wing likely would not look good on a convertible which is why i went with the v1 wing. if someone wants to photochop a v3 wing on a vert id love to see it!!
My Nismo side skirt extensions came in today. Looks like I have a weekend painting project!!
Old 02-12-2015, 07:52 AM
  #99
che69velle
che69velle's Avatar
I still say a removable hard top would completely sell the Nismo theme. All the top model roadsters have them, s2000 cr, Mazdaspeed mx5, etc so it makes sense that a Nismo would too
Old 02-12-2015, 10:09 AM
  #100
Bama J
Bama J's Avatar
Nissan 'been working on a Nismo Roadster too....
http://www.msn.com/en-us/autos/chica...ago/ar-AA9jnlG
Quick Reply: Project: Nismo roadster
