Audio Builds Audio projects and builds from my350z members
VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
Old 01-04-2008, 10:38 AM
350zspl
350zspl's Avatar
looking at the new pics your providing
the raising of the entire floor really won't be as hard as you feel
time consuming, but easy to understand, and easy to execute
your also adding a bit more net interior space to the enclosure by raising sub 3/4" higher out of the box
you may want to use t-nuts and bolt sub in just a thought
take your time , measure twice, cut once , be patient , you can do a very good job
if you want to get crazy and provide even more interior space to the box you can use 2 pieces of 3/4" mdf and raise the entire floor 1.5"
post pics along the way
you can get your T1 reconed by RF i think
Old 01-04-2008, 10:44 AM
StreetOC192
StreetOC192's Avatar
Now you tell him
Old 01-04-2008, 10:56 AM
VO...
Administrator
VO...'s Avatar
Received 2,747 Likes on 1,836 Posts
looking the new pics your providing
I'll make sure to take my time.
I'm currently using these T-nuts. They are only 1 1/2" long though. I'm going to have to purchase something longer.
http://www.partsexpress.com/pe/pshow...TOKEN=47605919
I believe I'll keep it at raising it 3/4" only. On the same note, I'd like to increase the inner volume to the max called for by FI. Any ideas on how much polyfill I should add to get the inner airspace up to 1.5 cu ft.?
Old 01-04-2008, 11:05 AM
cbr900son
cbr900son's Avatar
Nice job! Would love to see it in person.
Old 01-04-2008, 11:06 AM
VO...
Administrator
VO...'s Avatar
I just found the speaker fastners I need. They are 2 inches long. I'll place these on order today.
http://www.partsexpress.com/pe/showd...number=260-775
350zspl
350zspl's Avatar
on the 12" FI Q
sealed
.8 to 1.5 net
at 1.25 your there
with rasing your sub 3/4" your even closer to 1.5 net
i really hate polyfill, it is like a band aid for boxes to small, yours aint to small
since your using bolts - t-nuts- you can bolt and unbolt your sub without comprimising the integrity of your box
IMO i would use no polyfill
if after you feel you need polyfill unbolt sub , fill box, rebolt sub
i think your gonna have ideal net space without poly
Old 01-04-2008, 11:07 AM
VO...
Administrator
VO...'s Avatar
Thanks..
Old 01-04-2008, 11:08 AM
350zspl
350zspl's Avatar
you can take your t-nuts to home depot and buy new 2.5" bolts
they actually sell t-nuts and 2.5" bolts at depot
no need to speacial order from parts express
make sure your only using a t-nut once and the bolts once
sometimes the threads get messed up when used over and over
Old 01-04-2008, 11:09 AM
StreetOC192
The 1 1/2" long t-nuts should be good. I don't think you'll need longer screws. if you do, parts express should sell just the screws pretty cheap.
As for polyfill. There really is not accurate measure of saying "1 pound of polyfill will add X-number of cubic feet". It is a good rule of thumb to use 1 pound for every cubic foot of enclosure. If you have 1 cubic foot, then use 1 pound and the sub will 'think' it's in a larger enclosure......will it see a 1.5 cubic foot enclosure? probably pretty close. install it by gluing or stapling to the inside walls (all of them, including the baffle that the sub mounts to) about 2-3" thick (fluffy). It should take a full pound to make this happen in a 1 cubic foot box.
VO...
Administrator
VO...'s Avatar
I'll take your word for it and not use it. You hate polyfill, I hate unbolting the sub...
Old 01-04-2008, 11:10 AM
350zspl
350zspl's Avatar
Originally Posted by StreetOC192
Now you tell him
i had no financial gain from my info i provided
i just had a thought about recone
truly the T1 sounds WAY BETTER PORTED
sorry for the late tip
Old 01-04-2008, 11:12 AM
VO...
Administrator
VO...'s Avatar
I'll check it out on Saturday when I head up there to purchase the wood.
+1 on the t-nuts. I've had to cut a bolt off once with a Dremmel because the T-nut began spinning. Ruined the OEM mat. I had to buy a new one to the tune of $85.00...
Old 01-04-2008, 11:13 AM
350zspl
350zspl's Avatar
he will have 1.5" in wood
and maybe another 1/8" in sub height
t-bolts need to go thru the sub, wood , and 1/2 meat threads thru t-nut
2" might work 2.25 " or 2.5" will be ideal
Old 01-04-2008, 11:14 AM
VO...
Administrator
VO...'s Avatar
Nice! So if I'm interpreting this correct, 1 lb of poly fill is equivalent to around .5 cu ft., give or take a little?
Old 01-04-2008, 11:15 AM
StreetOC192
and maybe another 3/8" in sub height
Oh, the Fi subs have a 3/8" flange? I was unaware of that. I thought it was like most subs where you are bolting through stamped steel (or similar) about 1/8" -1/4" thick.
Old 01-04-2008, 11:17 AM
VO...
Administrator
VO...'s Avatar
Not to mention the 2 factory mats smushed inbetween...
Old 01-04-2008, 11:18 AM
350zspl
350zspl's Avatar
i have had 100 spinning t-nuts in my life at least
always keep a 10" extra hacksaw blade , and i have had to cut zillions this way
but if you hammer t-nuts well into box from the inside, and slowly fasten and unfasten bolts it reduces chances of spin
i have found the more i use t-nuts the luckier i get with the outcome
  #38
350zspl
350zspl's Avatar
meat to type 1/8 not 3/8 your right 100%
  #39
StreetOC192
When playing the game of "slowing down sound waves", it's more a matter of how thick the layer is on the walls and how dense you install it rather than the amount you put in. If you have a raw enclosure that is close to 1.5 cu ft, I would try without polyfil as 350zspl says. you can always add it if the sub sounds 'flat'. if your enclosure is closer to 1 cu ft, then I would throw in a pound of polyfil (cheap insurance at $4 a bag at walmart).
Old 01-04-2008, 11:20 AM
  #40
350zspl
350zspl's Avatar
oc192 is right 2" might be just perfect , but 2.25 or 2.5 will definelty be good
Quick Reply: VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
