Cd not ejected
Old Oct 18, 2007 | 06:37 AM
mattzroadster's Avatar
mattzroadster
Default Cd not ejected
Hello friends,
My factory cd will not reject the cd. when i hit the reject button it would makes lots of clicking noise, but the cd will not reject. Has this happend to any of us Z owner before? If so how do you manually fix it. I tried using sharp object into the cd mouth but nothing work!
Your help are greatly appreciated!
Old Oct 18, 2007 | 06:47 AM
SSZVirginia's Avatar
SSZVirginia
Common problem with the Blose. Nissan will tell you it has to be replaced. Is you car under warranty?
Old Oct 18, 2007 | 07:10 AM
RedLine 350z's Avatar
RedLine 350z
Try this. It usually works, but I would replace the factory CD if I was you.
Old Oct 18, 2007 | 07:30 AM
zeekle's Avatar
zeekle
i had a similar problem with another car. The CD player was faulty.
Old Oct 18, 2007 | 07:34 AM
Louis21's Avatar
Louis21
Is it the Bose or the base system? I haven't had any issues with the base system, but it's good to know in case it happens to me too. I can't believe the systems today are so damn crappy. My stock Mitsubishi eclipse system played CD's every day of its life till i sold the car without missing a beat for 10 years..
Old Oct 18, 2007 | 08:33 AM
tquill's Avatar
tquill
I've had the base since late 02 and it's happened to me like 2 or 3 times. A whole day will where I won't be able to get the CD out. So far it has come out the next day with no problems... I haven't had it happen to me in a while though.
Old Oct 18, 2007 | 11:01 AM
Lsmith9523's Avatar
Lsmith9523
You ask for a "manual fix-it",,,,My suggestion is a Hammer!
Then, go aftermarket....j/king...I hope you get it worked out,,,if not I would try the stealership....good luck.
kangol99
Mar 14, 2007 04:41 PM
ekstasis
Dec 2, 2006 11:15 AM
3hree5ive0ero
Apr 18, 2006 10:41 PM
orangeboy
Jul 18, 2005 03:53 PM
mwaller
Feb 10, 2003 01:44 PM
