FS: Upgrade your HIDs, only $39.99! Ships same-day!
#87
We do have ballasts, however if it was a factory ballast that went you would need to replace it with another factory ballast, our slim precision ballast and/or HYLUX ballast will not work as replacement. However, it might be cheaper to just go ahead and buy a new HID kit that include our ballast (with a lifetime ballast warranty) then to purchase a factory ballast, then tend to be expensive.
Hope that helps,
Michelle
Hope that helps,
Michelle
#88
on
Hope that helps,
Michelle
Hope that helps,
Michelle
#89
Wiring a new HID kit into a preexisting HID stock system is extremely difficult, but possible. Since it is different for every vehicle it is very hard to help and we do not have enough information guide you step by step. The easiest thing to do (but more expensive) would be to purchase the factory ballast, unfortunately.
Michelle
Michelle
#90
on
Michelle
Michelle
So the H.I.Ds kits that your selling for $89.99. there not plug and play for the a Nissan 350z, They have different connectors? I was about to order a kit, but I might just have to do some more research, I took Off my ballast from my headlight right now, all I have is one connector that goes straight to my main Headlight connector and one connector that holds my bulp, if it makes any sense lol Thanks for your time, I really need my headlight back up and running , I was under the impression that your H.I.D.s kits will be easy to install in my Z
#91
Unfortunately when cars come from the factory with HIDs it is a much more difficult process to install one our our kits. If you car did not come with HIDs our kits are extremely easy to install because there is no preexisting wiring to deal with.
Hope you solve the issue ASAP, let us know if you need any help finding info.
Michelle
Michelle
#92
on
Michelle
Michelle
