How-To: Front Bumper Removal/L.E.D Clear Corners Install w/pix + Ares's '06 CCs!
Old 01-11-2008, 01:51 PM
  #41
bamyi
bamyi's Avatar
One year later and this write up is still useful. Thanks Usman. By the way, your leds in the reflector and headlights looks realy REALY good.
Old 01-11-2008, 01:56 PM
  #42
deezz
deezz's Avatar
bookmarkin' this puppy. Very good write-up.
Old 01-11-2008, 09:52 PM
  #43
usmanasif
usmanasif's Avatar
That's how I roll, son. Hella tite.
Old 01-12-2008, 11:19 AM
  #44
RULE-1
RULE-1's Avatar
Default Clear Reflectors Install
I Also Did It Without Removing Wheels Or Bumper. Did Driver Side First By Removing 2 Bolts To Inner Wheel Well Skin. Other Side A Little Less Room, But I Used A Stubby And Ratchet Stubby. Looks Great and took 30 minutes.
Attached Thumbnails How-To: Front Bumper Removal/L.E.D Clear Corners Install w/pix + Ares's '06 CCs!-resize.jpg
Old 04-15-2008, 11:16 PM
  #45
ryanschram
ryanschram's Avatar
Originally Posted by veilsideV3Z
that looks good
if u want L.E.Ds in ur headlights check out clearcorners.com
they do an AWESOME JOB!!!
they do, if you're rich
Old 04-16-2008, 01:12 AM
  #46
mw9
mw9's Avatar
Nice, I needed some info on front bumper removal.
Old 04-16-2008, 08:02 AM
  #47
MI 35th
OGPremierMafia
MI 35th's Avatar
subbed thanks.
Old 04-23-2008, 08:09 PM
  #48
NTerrigno
NTerrigno's Avatar
Very good Write Up. This will help me a lot. Thank you!
Old 04-24-2008, 09:01 PM
  #49
lbz
lbz's Avatar
For 05's and older, there are a couple of good DIY threads on replacing the amber diffusers inside the headlights which the bumper does have to come off to do.
My new side reflectors are clear but without LED's. I've replaced the amber turn signal bulb with chrome covered ones since this pic was taken
[IMG][/IMG]
Old 05-23-2008, 05:26 AM
  #50
07rdsterGT
07rdsterGT's Avatar
Excellent. Exactly what I was looking for.
Old 05-24-2008, 11:36 PM
  #51
lbz
lbz's Avatar
You might consider swapping out the amber turn signal bulb for a chrome covered. small but nice touch for a cleaner look. nice write up.
Old 07-01-2008, 04:56 PM
  #52
Tomek350Z
Tomek350Z's Avatar
wanted to thanks OP for this write up, hardest part was passenger side because of that dam resvoir, also removal on clips first because i broke one
also did this without taking wheel off or bumper
Old 07-01-2008, 06:09 PM
  #53
Tomek350Z
Tomek350Z's Avatar
where did you buy yours becasue there are some on thezstore for 22 bucks called stealth bulbs
Old 08-04-2008, 10:14 AM
  #54
Rav3nRacing7
Rav3nRacing7's Avatar
I dont even like that b/c there isnt a HID kit on the front.... soooo the LED blue and the Halogen yellow looks gay... awesome guide to install....really good job.
I would go with a Xenon 10k or 8k.
Old 08-24-2008, 11:00 AM
  #55
stevezcar
stevezcar's Avatar
subscribed
Old 08-28-2008, 06:05 AM
  #56
Kiriller
Kiriller's Avatar
Any diagrams how to wire up 10 and 6 led's? Which resistors needed etc, thanks for help
Old 04-01-2009, 11:47 PM
  #57
Xzero
Xzero's Avatar
2 years, 9 months later this DYI is STILL useful!!! Great guide! I used it for headlight removal & it worked like a charm!
Thank you!
Old 04-26-2009, 12:15 AM
  #58
usmanasif
usmanasif's Avatar
Great to see that members are still benefiting from my little DIY. It's been a very long time since I wrote it and I should add that 5-6 months after adding those lighted reflectors, I painted my headlights and also installed white LEDs in them to act as parking lights. Some of them burnt out from the HIDs' heat within a few months so a year ago, while the car was in winter storage, I replaced the OEM front bumper with my perennial favorite, the Nismo V2, making the side markets unnecessary (thankfully!). Also, at the same time, I did the clear lens mod and installed halos around my projectors to act as parking lights. What a difference! This winter, I repainted the lights (from gray to black) and made some other changes, so now the car looks like this:
Headlights off:
Headlights on:
Color mod for the projectors:
Color band as it appears to the driver or pedestrian passing through the cut-off:
Old 05-01-2009, 07:25 PM
  #59
usmanasif
usmanasif's Avatar
Holy **** man. Pardon my French, but you don't know a damn thing about HIDs, do you? I wish I had seen this post before...you may be running a "kit" by now.
I mean, come on! Do you know how idiotic HID kits are? There is a reason why they are a ricer's illumination method of choice. The irregular light dispersion, hotspots, and resulting blinding of oncoming traffic are their signature. The 06+ Z's Koito projectors are very high quality and blow the ridiculous kits out of the water with their laser-sharp cut-off and intense beams. And 8K or 10K bulbs? Only someone interested in cutting their night time visibility by more than 50% (especially in the rain) would go with those. What I've done with the color mod is a million times better than anything a high Kelvin bulb can provide; the cut-off gives a momentary burst of intense color to the oncoming traffic while actually increasing light output since they aren't fresneled like the OEM lenses.
Old 07-19-2009, 09:04 PM
  #60
spinviper
spinviper's Avatar
Thank you it is helpful
Quick Reply: How-To: Front Bumper Removal/L.E.D Clear Corners Install w/pix + Ares's '06 CCs!
