DIY How to on Relocating your Cruise Control.
Old 12-11-2013, 08:50 PM
  #61
bmccann101
bmccann101's Avatar
Pm me your questions..
Sent from my DROID RAZR MAXX HD using IB AutoGroup
Old 01-19-2014, 04:39 PM
  #62
KingBaby
Hardest Setting
KingBaby's Avatar
Anyone recently do this on a 07/08 recently
Old 03-03-2014, 10:43 AM
  #63
Airkilo
Airkilo's Avatar
^ wanted to do this on my 2007. wanting to see if anyone has tried it yet on this year.
Old 03-03-2014, 11:45 AM
  #64
bmccann101
bmccann101's Avatar
its any different.. match colors at the combination switch, theres a plug for the cruise that goes right in back of it, pull it off, hang it down.. splice into it, plug the thing back in.. and mount your switch guts off the st wheel whereever youre crafty enuff to put it.
Old 03-03-2014, 03:09 PM
  #65
Airkilo
Airkilo's Avatar
Ah okay thanks. just wasn't sure if they changed the wire color or not. Or some bs like that.
Old 03-03-2014, 09:58 PM
  #66
KingBaby
Hardest Setting
KingBaby's Avatar
So....
just unplug the gray connect going into the swivel control and pair the wires to the cruise control?
prepped everything and plan to do that
Old 03-03-2014, 10:25 PM
  #67
bmccann101
bmccann101's Avatar
Yezzur.. the same colors for the wires in the column follow into the harness past the combo switch/clock spring.
Pull the plug and it makes it easier to splice into.. not sure why I plugged it back in after... just seemed a good idea I guess.
it was easier than I assumed it would be honestly....
Old 03-03-2014, 10:27 PM
  #68
KingBaby
Hardest Setting
KingBaby's Avatar
awesome...after post #64...I got off my *** and knocked it out....
I was like
"he makes it sound so easy"
Old 03-05-2014, 08:28 AM
  #69
bmccann101
bmccann101's Avatar
it is, really. glad i got you movin!
Old 03-09-2014, 07:06 AM
  #70
nofrey
nofrey's Avatar
Interested in doing this...where did you guys relocate the switches to?
Old 03-13-2014, 07:26 AM
  #71
3hree5ive0ero
Retired Admin
3hree5ive0ero's Avatar
Somebody should do a more detailed DIY with lots of pictures..
Old 03-17-2014, 03:24 PM
  #72
KingBaby
Hardest Setting
KingBaby's Avatar
Default 07/08 wiring
So in addition to this DIY for 07/08 guys confirming it works as well.
Once you remove the cruise control panel from the steering wheel as instructed.
Remove the gray connector and peel away the plastic shielding so you can tap into the following wires...then plug it back it seeing you more than likely want the horn to work!
Black cruise control wire to the gray connector's black with yellow strip
Red cruise control wire to the gray connector's mostly Green with yellow strip
Will upload a picture later of the wiring
Picture of my final setup, if you remove the lower steering column plastic covering. The two mounting points that attach that cover can be used to mount a "L" shaped bracket to screw in the cruise panel.
All in all very simple and pretty straight forward
Old 03-19-2014, 06:41 AM
  #73
DmanG281
DmanG281's Avatar
I just did this and put mine in the little coin pocket in the console. I took all the pieces off and just have it in there snuggly. I cut a slit in the coin deal so I can remove it when I need to. I removed the 2 screw posts and shaved it square to make it fit also.
I tried to figure out a way to reuse the steering wheel plastic piece it fits into in the cubby but never was happy with how it looked.
Old 03-19-2014, 06:42 AM
  #74
DmanG281
DmanG281's Avatar
There really isn't much more to it. The pictures from the OP were all that was needed IMO.
Old 03-31-2014, 10:28 AM
  #75
KTran
KTran's Avatar
I relocated mine 2 yrs ago and just made a simple bracket bolt to hub setup,
no wires were cut, stock length was actually too long and had to loom it up'
took a few snaps
Old 05-15-2014, 05:01 PM
  #76
Dabsedan
Dabsedan's Avatar
Deleted
Old 08-11-2014, 05:15 PM
  #77
hardtoocatch
hardtoocatch's Avatar
Do u need to keep the cruise control plug in after u do an aftermarket wheel cause I didn't and am getting a cel P1564 looked it up an is for the ASCD automatic speed control device which is the cruise control.
Old 10-28-2015, 11:13 AM
  #78
RedLine_ZR
RedLine_ZR's Avatar
Dug this up just as a reference for anyone who decides to do it. Got around to doing it after not having cruise control for a year because of switching my steering wheel.
Old 10-28-2015, 11:50 AM
  #79
Depravity
Depravity's Avatar
^^^ That looks really good. I would like to do this on my HR soon
  #80
KingBaby
Hardest Setting
KingBaby's Avatar
nice !!!
Quick Reply: DIY How to on Relocating your Cruise Control.
