Upper Control Arm Balljoints
350Z/370Z Tech Moderator
Slightly off topic: Last time I brought my wife's Z to the dealer for service (service contract dontcha know it!), I had them align it and purchased a "lifetime alignment" from them. It cost $20 more than standard alignment and I've had them check it and give me a readout each time we brought it in for regular serviciing. Might be worthwhile for you.... hahaha.
on
Update: I installed the new ball joints, but its still making the noise but only of the drivers side. Its not as bad but still, its embarrassing to drove around with that creaking!!!!!! Im going to add more grease but if this doesnt end up working I am just going to save up and buy SPL's.
on
So Megan Racing sent me another pair of balljoints and I replaced these. Then I noticed when I had the car jacked up from the front, I turned the steering wheel without having installed the new parts. It happened to be my strut mounts on my coil lovers. I just went ahead and bought BC racing coils and the noise went away!! I threw away the crappy ebay coilovers. Thanks for those who gave me suggestions.
So it ended up being the front pillowball mounts on the cheap ebay coilovers, nice work on reporting back.
Note though that on our platform the coilovers are just coilovers, they are not part of a strut assembly, meaning the coilover does not rotate when you turn the wheel. The sound was probably the result of the suspension changing height as you turned the wheel causing the pillowball to creak. Which is interesting because by that logic you should have heard it even when going over bumps and such.
The problem with that Megan joint is likely poor boot design (among other things). The boot was binding during turns, which eventually tore the rubber (which seems to be in good condition otherwise). It doesn't even sound like you are that low, but as long as they weren't creaking or sloppy they were technically fine.
Let us know how the new ones hold up.
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
04-04-2016 07:52 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
