Drag NHRA, IDRC, IHRA, NDRA
Will these wheel/tires work?
Old Jun 13, 2006 | 05:04 PM
oo_snoopy's Avatar
oo_snoopy
Default Will these wheel/tires work?
I apologize for not figuring this out on my own and I did do some seraching, but i'm a really big newbie when it comes to this time/wheel stuff and would rather not go off my own guessing. Anyways, will these wheel/tires work?
Wheel specs:
16x8
5x114.3mm / 5x4.5 bolt pattern
+50mm offset
Tire specs:
MT ET Street (bias)
26x10.50x16
-Thanks!
Old Jun 14, 2006 | 06:14 AM
Alberto's Avatar
Alberto
Cranky FI Owner
The tires are good to go, the bolt pattern is good to go but that 50mm offset I dunno man. High 30's offset on our cars looks WAY tucked in I wouldnt run that offset myself.
Old Jun 14, 2006 | 04:06 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
we are running 5.5 inches of backspacing at least on ours. i would check into that and make sure you have at least 5.5 BS
Old Jun 14, 2006 | 04:14 PM
bacalhau16's Avatar
bacalhau16
oo snoopy just curious, but what kinda suspension are you going to use to compliment that wheel/tire setup?
Old Jun 14, 2006 | 06:42 PM
jackie chan's Avatar
jackie chan
his stock susp will be fine with those tires. if you need to find a cheap wheel set up, look into some 16" mustang wheels. they will be kinda narrow(7.5) but will work with those tires. I use to run 26x16 et strees on my old vert, it yanked the fronts a lil. now im running the 17s but they are too tall....gonna have to spray
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
