I need help identifying the VLSD
Old Jul 19, 2008 | 04:37 PM
weak 350z's Avatar
weak 350z
Default I need help identifying the VLSD
Does anybody know what car this came out of? Thanks for any help.
Old Jul 19, 2008 | 04:59 PM
R-TuneZ's Avatar
R-TuneZ
where did you get it?
Old Jul 19, 2008 | 05:03 PM
surfcity40's Avatar
surfcity40
I'm guessing it's an OKN 5421 395
http://en.wikipedia.org/wiki/Open_Knowledge_Network
Old Jul 20, 2008 | 05:31 AM
weak 350z's Avatar
weak 350z
I was picking up a long block at a nissan dealership and it was there and I asked for it.
Old Jul 22, 2008 | 12:23 PM
weak 350z's Avatar
weak 350z
anybody?
Old Jul 22, 2008 | 03:43 PM
R-TuneZ's Avatar
R-TuneZ
why don't you ask whoever you got it from...
Old Jul 24, 2008 | 04:49 AM
JOEGYVER's Avatar
JOEGYVER
If you turn one axle flange in one direction, and the other side turn in the opposite direction, it is an open differential, so then it is a 3.5X MT ratio. You could try to rotate the axle flange and count the driveshaft rotation as a proportion to attempt to determine whether it a 3.3X 5AT or 3.5X MT, but not likely, so I would drain the fluid, pull the cover and count the ring gear teeth. You will have to look up the count, I can't remember, but the 3.3 has more teeth than the 3.5, and the pinion tooth count is different too, but you cannot really see it behind the diff. I will try to get the toothcount sheet I have at home if you don't find it. Also, some/all ? auto G35s had a different ratio than the auto Z, too, you will have to research.
Old Jul 24, 2008 | 02:50 PM
Z04's Avatar
Z04
that would be too easy. instead we got a picture of a rear differential and we have to play guess what it is
Old Jul 24, 2008 | 03:12 PM
weak 350z's Avatar
weak 350z
It is a VLSD. I just wanted to know what vehicle it came out of. Anybody know. I think its a 3.5.
Old Jul 24, 2008 | 03:46 PM
R-TuneZ's Avatar
R-TuneZ
Old Jul 25, 2008 | 06:00 AM
JOEGYVER's Avatar
JOEGYVER
Pull the cover off and count the ring gear teeth, it will take all of five minutes. I will count teeth on my old 3.3 after work. I am pretty sure I have a spec sheet that had the 3.3, 3.5 and 4.08 ring and pinion toothcounts, but have to dig...
Old Jul 25, 2008 | 01:40 PM
Z04's Avatar
Z04
and again, go ask the people that took it out what car it came off of. how hard is that?
and no, that is a rear differential. the VLSD is the parts inside of it.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
pslamp32
Sep 14, 2015 03:05 PM
dklau33
May 27, 2004 10:19 AM
