5AT gears
Old Nov 23, 2010 | 06:37 PM
Fo350z's Avatar
Fo350z
Thanks, CustomG. What do you mean by 'on driver'? I did just read a thread about a swap of one into an M/T 350z. Not sure if there would be a difference though with an A/T?
Old Nov 23, 2010 | 07:55 PM
Fo350z's Avatar
Fo350z
I figured out what you meant... g35driver. I found this thread - http://g35driver.com/forums/drivetra...tial-swap.html - interesting stuff!
Old Nov 24, 2010 | 05:17 AM
R3belzBRN's Avatar
R3belzBRN
thanks for the guide guys. appreciate the help =)
Old Nov 24, 2010 | 08:41 AM
CustomGsedan's Avatar
CustomGsedan
yep, that's the one ~
Old Nov 24, 2010 | 10:55 AM
SexyRob's Avatar
SexyRob
my 06 5AT G has 3.5 stock, so not all AT diffs are 3.3 you could get lucky and find one with 3.5 and not have to get a MT diff.
Old Nov 25, 2010 | 06:11 AM
CustomGsedan
^^^ what makes you think you have 3.5 stock in an AT?
Old Nov 25, 2010 | 06:24 AM
andre12031948's Avatar
andre12031948
Default 3:50/3:70 in auto-3:90/4:08 in 6mt-my 2 cents
Old Nov 25, 2010 | 08:11 AM
SexyRob's Avatar
SexyRob
check the 2006 and 2007 g35 service manual.
2005 has them seperate into 3.3 for auto and 3.5 for manual
2006,7 has them combined 3.5 for all.
Old Nov 25, 2010 | 09:17 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
that would have to be a typo, all auto's have 3.3, all manuals have 3.5.
Old Nov 26, 2010 | 05:20 AM
SexyRob's Avatar
SexyRob
a typo in two years of the service manual?
I mean I thought that too but really??
someone in a 6MT tell me what there Revs are when driving 80, mines like 3.4k. At 75 it's at 3.2k in 5th gear
**I just downloaded a 2006 g35c service manual from a different source and it looked the same.**
Old Nov 26, 2010 | 06:37 AM
CustomGsedan
^^^ I was unaware that any pre 07 AT were not 3.3... strange that you are 3200rpm @ 80 though - I'm 3200-3250 with 3.7
Old Nov 26, 2010 | 07:04 AM
SexyRob's Avatar
SexyRob
well with 7 gears your last gear is smaller than my last gear (5th vs 7th) so even when combined with 3.7 your revs will be lower in that last gear.
I guess I need to figure out what other 5AT owners are running at RPM wise.
Old Nov 26, 2010 | 07:48 AM
CustomGsedan
I am 5AT (replaced OEM 3.3 with 3.692)... 80 when I had 3.3 was 3Krpm
Old Nov 26, 2010 | 07:54 AM
SexyRob's Avatar
SexyRob
oh my bad, so you are saying that with your 3.7 you are lower rpm's than me? thats odd.
Old Nov 26, 2010 | 03:36 PM
CustomGsedan
yeah it is odd... 3400 @ 80 seems quite high... higher than most 5AT that do 3.5 swap... here's a reference link to show what several others rpm is:
http://g35driver.com/forums/drivetra...ms-80-mph.html
Old Nov 26, 2010 | 04:11 PM
Z1 Performance
Former Sponsor
will also be subject to tire size
Old Nov 26, 2010 | 06:26 PM
SexyRob's Avatar
SexyRob
well I'm runnnin F 245/40/18, R 275/35/18
I did do a LED swap so its possible my tach is off by a little bit. Ill plug in the laptop and check it with cipher tomorrow to be sure.
Old Dec 28, 2010 | 11:50 PM
  #38
power2rice's Avatar
power2rice
you are under sized at 275/35/18. i'm running 265/40/18 with 3.7 gears on my 5at and my speedometer is off by 5mph exactly. at 80 i'm actually only doing 75mph.
Old Dec 29, 2010 | 11:17 AM
  #39
SexyRob's Avatar
SexyRob
I data logged in cipher and my RPM's were at 3200 at 80 not 3400 as my gauge cluster showed. still within the range of 3.5 gears
Old Jan 26, 2011 | 11:13 AM
  #40
mgrotel's Avatar
mgrotel
im 06 g35 5at, pretty sure i have 3.5fd ratio
