lost 20 whp.. what could have been the problem?
Old 06-30-2012, 10:03 PM
akt
akt's Avatar
here are the dynograph
Old 06-30-2012, 11:48 PM
jerryd87
jerryd87's Avatar
its a pretty consistent loss across the bored except for that very small spot between 3200-4000 which its untelling what that can be. you dint specify the different temps your looking at about a 9% drop in power which would equate to about a 20 degree temp difference on days my bet would be on that. otherwise the only possible conclusion could be the tuner isnt running enough spark across the board or is running too much except for that small rpm range and causing spark retard.
you lost power down low which is to be expected from that combo but you went with a better flowing intake(that was with mrev+spacer right?) and cams to match. which means you should be making more power up top. since you made the power before its either weather conditions(my bet now that i see the dyno) or your tuner really fubared your tune.
Old 07-01-2012, 01:47 AM
e30cabrio
e30cabrio's Avatar
Received 2,578 Likes on 2,037 Posts
I have S7 cams on my stroker and have good power and torque.
Did you uprade the valves & port the heads? I have Manley large valves and had the heads done.
Sorry you are having problems, I know how frustrating it can be.
Old 07-01-2012, 02:30 AM
Exemption
Exemption's Avatar
its frustrating just thinking about it. Sounds like its a tuning issue or intake problem. You should be taking in more air with those mods...maybe timing?
Old 07-01-2012, 02:39 AM
e30cabrio
e30cabrio's Avatar
Now that I am thinking about it, after the stroker went in, my cai which was a Fujita tube from the throttlebody connected to an Injen rubber hose going to an Amsoil filter between the bumper and radiator support. It worked great pre built motor but caused crazy MAF correction costing 20-40 hp on the stroker. When I switched to a Z tube & Pop Charger it all came back.
Old 07-01-2012, 04:52 AM
akt
akt's Avatar
The weather here is pretty much the same year round, so i guess weather isnt not a factor. I already removed the mrev2 and will dyno it tomorrow. Will update you guys. Thanks
Old 07-01-2012, 04:53 AM
akt
akt's Avatar
Everything is still OEM/stock inside the engine except for the JWT s7r cams, springs and shim. No headwork yet.
Old 07-01-2012, 12:31 PM
jerryd87
jerryd87's Avatar
headwork isnt going to be a issue not at that low rpm, the heads on our engines have shown to support almost 8k rpms with just cams, springs and retainers at more power then your pushing. plus thats going to further slow down air velocity, the only reason for headwork is to push the absolute limit NA or go for insane power FI.
Old 07-01-2012, 12:45 PM
e30cabrio
e30cabrio's Avatar
I did it because what point spending a fortune on a stroker build and save under 1k in valves/springs/head work.
I was positive with my 11.0.1 compression I was not going FI.
Old 07-01-2012, 03:27 PM
jerryd87
jerryd87's Avatar
in your case its a bit different with a stroker lol a 3.5L shouldnt need it.
Old 07-02-2012, 07:18 AM
binder
binder's Avatar
jerry, 276 down to 263 is only a 4.8% drop in power when i calculate it. Did i calculate it wrong?
That amount of drop is within a standard variant on a dyno. The fact that it's consistent across the entire dyno makes one think that it would be something other than the tune. Error rate in the dyno, ambient temps or humidity, etc.
OP, i know you said the temps stay the same but you are on an island, correct? so humidity can swing day to day. Humidity has a considerable effect on horsepower. Also, do you know if there were any software or firmware updates on the dyno over the past year?
Since the cams were changed, did he tune cam timing? Optimizing cam timing for aftermarket cams in an NA engine is crucial to getting power gains.
Old 07-02-2012, 10:40 AM
jerryd87
jerryd87's Avatar
nah jeff i wasnt paying attention and went off the untuned number haha
the only thing is that one section where the power is pretty much equal is what kinda struck me as odd i would have thought it would have been everywhere but yah weather can have that big of a impact. very well could be the cam timing as well.
Old 07-02-2012, 10:49 AM
Jtran Studios
Vendor - Former Vendor
Jtran Studios's Avatar
running that afr in the midrange will definitely have a spark retard event or a "high detonation knock" reducing the amount of timing through redline. i would get him to retune it and also look at his cam timing map.
Old 07-02-2012, 07:00 PM
binder
binder's Avatar
good point, a/f is a little high.
Old 07-07-2012, 12:31 AM
akt
akt's Avatar
Thank you for your inputs! I will have my tuner check the cam timing and midrange afr. keep you guys posted. thanks again
Old 07-15-2012, 10:23 PM
akt
akt's Avatar
using the same map with and w/o the mrev2 long runners
had a higher hp w/o mrev2
better torque with the mrev2
Old 07-16-2012, 07:33 AM
binder
binder's Avatar
If you plan on running out past 6500 then i definitely would go with the blue dyno. The peak numbers mean nothing. That blue dyno holds a considerable more amount of hp up top as well as torque. The red dyno seems to have a little more around the 5500 mark but has quite a bit of drop off in the upper rpm range.
Old 07-16-2012, 01:03 PM
  #38
Esser
Esser's Avatar
There are tons of factors that come into play, but it could really be anything:
Type of fuel
Humidity
Temp
Dyno variance
Tire type/wear (yes it affects it)
Engine wear/compression
Or it can really come down to who is operating the dyno, and who is doing the tuning compared to last time.
And it's not the gears because that will only affect your torque, not HP
And considering that you lost HP when you installed the MREV2, it leads me to believe that you need head work done. The larger cams are simply not getting the steady amount of air volume that they need. I would consider finding someone to port and polish your heads.
And if you didn't change valve springs during the cam install then you may run into problems down the road....
Old 07-16-2012, 03:49 PM
  #39
F2CMaDMaXX
F2CMaDMaXX's Avatar
So, you lost 2 HP peek with the MREV2? That's correct, you need the shorter runners to get that, but what you gain is not just the 2 peak Tqm it's the area under the curve, you'll notice that with the MREV2, you gain almost everywhere else, all through the range.
Old 07-17-2012, 04:43 AM
  #40
akt
akt's Avatar
Thanks for your inputs.
I already talked to someone in JWT and I'm just waiting for their engineers to reply.
I'm going to return my mrev2 since they have better power through out. With regards to headworks it might be an options, but I'm still waiting for jwt's engineers inputs. I also might need to increase my compression ratio. or just go for boost (long shot since I'm afraid the car might not be reliable anymore )
Quick Reply: lost 20 whp.. what could have been the problem?
