Car not going into gear after clutch install
Old 09-18-2014, 04:53 PM
Norman
Norman's Avatar
Default Car not going into gear after clutch install
My car is at the shop right now and we just got done installing a centerforce DF clutch and an act pro lite flywheel. Everything lined up right and bolted up perfectly. Install was done we drove the car around the block and found it hard to put into gear. The pedal also wasn't coming back up all the way. I tried bleeding the master cylinder and no fluid was come out just a little squirt. Now the pedal is on the floor and it won't come back up. Need some help ASAP please!
Old 09-18-2014, 07:37 PM
92K1500
92K1500's Avatar
What year is your car? There are 2 slave cylinder setups.
With the pedal stuck to the floor you have air in the system. Reach down there and pull it back up.
Is there anything in the reservoir?
Old 09-18-2014, 07:56 PM
Norman
Norman's Avatar
It's an 04. The resovoir is full and I have been pumping it but the fluid isn't draining out.
Ace2347
09-22-2015 03:12 AM
Quick Reply: Car not going into gear after clutch install
