Clicking Noise from Rear Axle,
Old 01-01-2013, 07:58 PM
  #161
F2CMaDMaXX
F2CMaDMaXX's Avatar
Not likely on the loose nut, but it will have shocked anything that was stopping the click.
It's all interference and the grease is just there to keep it quiet, mine has quietened down completely since it got cold.
Old 01-02-2013, 11:16 AM
  #162
srsairbags
srsairbags's Avatar
Should i go back to the shop that did the brake install to ask them to look at it (they are a performance shop) or I should just print out the TSB and go to a regular workshop (out of warranty )
Also my car is from FL . . rececntly moved to TX and is getting a taste of its first severe winter . . .you think that might have aggravated the issue ?
Old 01-02-2013, 06:27 PM
  #163
F2CMaDMaXX
F2CMaDMaXX's Avatar
If you don't want to do it yourself, sure, take it in somewhere with the TSB.
It's not any fault of the perf shop, it's just something that can happen as parts move.
Old 01-25-2013, 01:58 PM
  #164
tylerxfire
tylerxfire's Avatar
i took the axle out tonight..wasnt a problem, having a real hard time though finding the right grease..i have an advanced auto, autozone and napa to choose from..none have molykote m77 obviously but then i read that citgo lithoplex mp wheel bearing grease is a good solution which i cant find..what did everyone use with success and how long has ur click been gone..thanks in advance..also i did find this on ebay http://www.ebay.com/itm/DOW-CORNING-...item416d4f1baa which is what it calls for and considering just buying this but id rather find something local if it works just as good..
Old 01-25-2013, 04:03 PM
  #165
jerseystyle
jerseystyle's Avatar
Right grease? Honestly, it doesn't matter.
Old 01-25-2013, 04:21 PM
  #166
F2CMaDMaXX
F2CMaDMaXX's Avatar
Some thick marine grease should suffice.
Old 01-25-2013, 04:28 PM
  #167
tylerxfire
tylerxfire's Avatar
yes it actually does matter quite a bit once you get into it..has to be insolulable and withstand alot of heat, and be ok against diff. elements and such and be successful to withstand metal to metal contact..not all greases are the same..a plane jane wheel bearing grease will wear off in no time..i plan to do this once and not have the issue come back
Old 01-25-2013, 04:29 PM
  #168
tylerxfire
tylerxfire's Avatar
thats what im leaning towards..gonna check it out tomorrow..thanks
Old 05-09-2013, 02:54 PM
  #169
sean13
sean13's Avatar
would it help if we spray some W40 instead of taking all those bolts off?
Old 05-09-2013, 03:04 PM
  #170
OldManZ350
OldManZ350's Avatar
This works great.... You can get it at Napa and many other autoparts.
Make sure you also coat the Splines as well.
http://www.permatex.com/products/pro...bricant-detail
Attached Thumbnails Clicking Noise from Rear Axle,-screen-shot-2013-05-09-at-7.00.50-pm.png
Old 05-09-2013, 03:11 PM
  #171
OldManZ350
OldManZ350's Avatar
If you must have M77, but it's 3x the money by the time you add in shipping.
http://handa-accessories.com/ridgelinemaint.html
Attached Thumbnails Clicking Noise from Rear Axle,-screen-shot-2013-05-09-at-7.07.55-pm.png
Old 05-09-2013, 03:44 PM
  #172
F2CMaDMaXX
F2CMaDMaXX's Avatar
WD will not do *anything*, so no it won't save you removing the bolts
Now the weather has heated up, mine are clicking and cracking both sides, nearly everytime i start off, it's really embarrassing Gotta make time and get this done
Old 09-15-2014, 09:06 AM
  #173
limited733
limited733's Avatar
Hi guys i have a 370z but have the same noise every time i brake for example when i park the car. It sound like this:
https://www.youtube....MVrRLWQ&index=3
https://www.youtube....MVrRLWQ&index=2
I put last weekend some grease as suggested but it did not do the trick. Do you guys have any other ideas?
Old 09-19-2014, 12:02 AM
  #174
Hgomez809
Hgomez809's Avatar
I know this post is old, but i just wanted to say Thank you for the good tutorial. I did this today and it works pretty good.
The nuts are a pain to take off!!
Thank you.
Old 10-17-2014, 02:19 PM
  #175
Davidian
Davidian's Avatar
Gonna do this tomorrow as I had to take the axles off to get to the rear wheel bearings when I replaced them. Now that I have the m77 grease, I wanna grease my axles properly.
Old 10-28-2014, 09:30 AM
  #176
Pat_Man
Pat_Man's Avatar
Helped a lot thanks!
Old 04-27-2015, 05:42 PM
  #177
Davidian
Davidian's Avatar
Forgot to update this. After applying the m77 grease, axles are quiet again!
Old 05-17-2015, 07:11 PM
  #178
jawolf07
jawolf07's Avatar
I realize this is an old thread but I had a few questions? I have a ticking noise coming from the rear when I let off of the accelerator at higher speeds. I just noticed the noise after I had a new clutch installed. Could the axle be the issue or could it be something to do with the clutch?
Old 05-17-2015, 10:18 PM
  #179
OldManZ350
OldManZ350's Avatar
I dought it's your clutch.
Another problem area are the u-joints in the drive shaft.
Look under the car for any signs of greese splatter on the bottom side of the tunnel in the area around the u-joint.
Old 05-18-2015, 07:25 AM
  #180
Italianjoe1
Italianjoe1's Avatar
If it was something that showed up after the work was done, it may be something that wasn't installed tight enough, have whoever did the clutch check it out.
Quick Reply: Clicking Noise from Rear Axle,
