FS: Built Vq35de With Accessories $13,500
on
Built Vq35de With Accessories Part out!
Hi I have my built vq35de engine that was only ran for about 20 mins never seen a street. Got a built ls that will be going in the car and no long have a need for it. i will be parting this engine out if anyone would like anything please let me know thanks!
Block
Sleeved Vq block
billet main girdle
acl race main/rod bearings
oil pan spacer
eagle rods
cp pistons
Arp L19 Head and Main Studs
Hks Head Gaskets
Heads
5 angle valve job
Ported Heads
Ferrea Comp Plus Valves
Ferrea Dual valve springs
Ferrea Retainers and Valve locks
Brian Crower 272 cams
Gtm Twin turbo cast Manifolds
Gtm 5 bolt downpipes
Injector Dyamatics ID2000 Injectors
Lightweight polished Pulleys
Asking for $11k For everything have well over that into all of it this is a steal for someone looking to get into a built vq set up for there Z/G.. Buyer is Responsible For pick up/Freight May part out for certain things but would like to sell as whole package if possible Contact 815-297-7662 Thanks
Block
Sleeved Vq block
billet main girdle
oil pan spacer
eagle rods
cp pistons
Hks Head Gaskets
Heads
5 angle valve job
Ported Heads
on
Because when I started building this engine I thought I knew what I was doing and got way deeper into then what I realized was need. I Found out thousands of dollars later that this was a expensive platform. I never took the car out because I by the time I got it done I decided to go with a lsx swap and I am picking one up fairly cheap and would like to just get as much back out of this as I can before I loose more money on it that is why I never got any farther then it did. If I can not get a good amount of money back I will be keeping this setup. The CR was 8.5 to 1 and I will have to call the Shop and get Clearances if you are interested.. Thanks!
11-09-2020 10:27 AM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
