Drama
Old Apr 22, 2010 | 09:02 PM
Cannysage's Avatar
Cannysage
Default Drama
I come back and all I see is a lot of drama.. good to see that nothing's changed..
Boost and the Restless........
anywhoo.. I'm running rich (10s) any way to lean out a bit without getting fresh retune?
Old Apr 22, 2010 | 09:21 PM
midz350's Avatar
midz350
Do you have a RFS with a regulator?
Old Apr 22, 2010 | 09:25 PM
thom000001's Avatar
thom000001
Turn up the boost!!!!!
Old Apr 22, 2010 | 09:40 PM
Cannysage's Avatar
Cannysage
I have cjm, but not sure about it having a regulator. whether it does or not, there's gotta be a way.
Old Apr 22, 2010 | 09:57 PM
Entaille's Avatar
Entaille
canny, where do you get your screename from?
Old Apr 22, 2010 | 09:59 PM
midz350's Avatar
midz350
you can do that
Which stage?
Old Apr 23, 2010 | 04:55 AM
QuadCam's Avatar
QuadCam
if you have a CJM return setup, you probably have a red fuel pressure regulator mounted to the firewall, behind the intake manifold. You could adjust your base fuel pressure down a few psi.
but first, is it running rich only at WOT? through the entire rpm range? what about part throttle, low boost situations?
dropping the base fuel pressure is a global change......not very precise. It's kind of like a surgeon using a steak knife when he should be using a scalpel; it'll get the job done but it may affect areas not needing adjustment.
Old Apr 23, 2010 | 08:07 AM
Elperuano's Avatar
Elperuano
[QUOTE=QuadCam;8326992]if you have a CJM return setup, you probably have a red fuel pressure regulator mounted to the firewall, behind the intake manifold. You could adjust your base fuel pressure down a few psi.
dropping the base fuel pressure is a global change......not very precise. It's kind of like a surgeon using a steak knife when he should be using a scalpel; it'll get the job done but it may affect areas not needing adjustment.[/QUOTE]
lol ouch
Old Apr 23, 2010 | 09:23 AM
Cannysage's Avatar
Cannysage
at wot. i don't mind leaning out the entire range. I guess I'll call up some local tuners.
made it up over 10 years ago for an online game. duke nukem, i believe
silvrhand
Texas
19
Aug 16, 2006 05:00 AM
