Another TT NISMO 370Z
You guys pulled out on Rt 17 in NJ? Either way, I always rip it on that section of the turnpike.
If I'm wrong on both, I'll be disappoint.
That M6 isn't stock, right? I've raced one in my Caliber SRT4 and I pulled on it (300whp/300wtq). I thought they're around 450whp stock and they're pretty heavy, too.
Well, on our dyno and two other dyno's he put his car on, it made between 486-500whp on only 6psi.
The engine itself is not built, but a lot other then just the TT kit went into it.
I used the word built because, well, what other word should I use to describe that we did all the labor and custom fabricating on some things as well as the tuning? it just sums it up
Vendor - Former Vendor
the main stuff done to the black one:
GTM Stg1 TT Tuner Kit
CJM Stage 0 Fuel Return System
ID 725cc Injectors
255lph Walbro Pump
PerformanceMotorsport 25Row Oil Cooler Kit
OS Giken Twin Disc Clutch & SS line
UPREV Pro Tune
The camera I shoot with is a Nikon D300s. And the lens that I mainly use is a Nikkor 18-70mm 3.5. As for the settings. It varies bc I shoot on fully on manual so the shutter speed, aperture, white balance, iso etc... changes every few shots.
UPDATE: The thread following the build can be found here:
https://my350z.com/forum/media-share...smo-build.html
04-04-2016 07:52 AM
xirtam
10-03-2015 02:06 PM
