OEM Plenum / Intake Manifold Bolt Sizes
OEM Plenum / Intake Manifold Bolt Sizes - VQ35DE
There are a bunch of threads on here asking for the sizes of the OEM plenum nuts & bolts. There's some info in the FSM, but, surprisingly, even Nissan's fast system doesn't have the complete specs. Anyway, the OEM sizes are below - add 8-10mm if you're running a 5/16" plenum spacer.
Intake Manifold Collector (Upper)
Bolts 1, 3, 6, & 9 = M6 x 1 x 60mm (red)
Bolts 2, 4, & 5 = M6 x 1 x 45mm (yellow)
Bolts 7, 8, 10, 11, 13 - 16, & 18 = M6 x 1 x 25mm (green)
Nuts 12 & 17 = M6 (green; these nuts & studs are sometimes replaced with M6 x 1 x 25mm bolts in aftermarket applications)
Intake Manifold Collector (Lower)
Bolts 1-6 = M6 x 1 x 70mm (blue)
Nuts 7 & 8 = M6 (violet)
hopefully this helps someone who wants to go back to stock, but has misplaced their OEM bolts.
christoc (02-29-2016)
on
Well this thread is awesome. My brother broke one of my bolts that are supposed to be torqued in Inch-Pounds (The blue bolts) and we needed to find replacements. Thanks!
