Exhaust Ideas
Old 02-27-2015, 10:29 PM
  #41
ZBeastZ
ZBeastZ's Avatar
Okay that's good information to have thanks! So in your guys' opinion, what is the best first mod to make? Assuming you only want to spend a couple hundred or so dollars.
Old 02-28-2015, 05:54 AM
  #42
woody03
woody03's Avatar
Plenum spacer.
Old 02-28-2015, 12:37 PM
  #43
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
agreed
Old 03-02-2015, 04:45 PM
  #44
ZBeastZ
ZBeastZ's Avatar
Okay I will look into that, I have heard of it before but am unsure of what it does exactly, what does it do and what will it affect?
Old 03-02-2015, 04:50 PM
  #45
ZBeastZ
ZBeastZ's Avatar
Do you guys recommend 5/16" or 1/2"? Also, I read that if you do this mod you can still fit the engine cover but not the stock sway bar. If I don't put the engine cover on, can I keep the sway bar?
Old 03-02-2015, 04:59 PM
  #46
woody03
woody03's Avatar
5/16. The engine cover fits fine and the strut bar fits fine. Has nothing to do with the sway though.
Old 03-02-2015, 05:01 PM
  #47
ZBeastZ
ZBeastZ's Avatar
Sorry I meant the strut bar! Okay thanks, and since I live in California im assuming I don't need the copper one correct? What would be the difference between 5/16" and 1/2"? I'm assuming more power from 1/2" but would the strut bar and engine cover not fit?
Old 03-02-2015, 07:12 PM
  #48
Cap11
Cap11's Avatar
Do the 5/16. You won't need the copper unless you drive the car in under 50 degree weather.
Old 03-02-2015, 08:23 PM
  #49
ZBeastZ
ZBeastZ's Avatar
In the winter it gets in the 30's and 40's but doesnt snow at all, it will freeze over a little! Any advantages or disadvantages to either?
Old 03-02-2015, 09:01 PM
  #50
Conway_160
Conway_160's Avatar
I have a 5/16 and drive my car when its in the negatives with no ill effects.
Old 03-02-2015, 11:18 PM
  #51
Resmarted
Resmarted's Avatar
Copper won't matter.
Intake spacer I doubt will be noticed in a smog check. If it is, it's a real easy fix. I've taken my plenum off a million times. It's so easy.
DIY your own cold air intake and get a spacer. Buy a cheap dual 2.5" to 3" Y pipe on ebay. It will bolt up to your stock midpipe, get gains, and cost 150$ or less. Keep your stock intake for smog time. Or incase you get a ticket. Also a super ridiculously easy mod to revert to stock.
As for exhaust in general, in California everything behind the cats is fair play, as long as you "don't have a cut out" and have "adequate muffling". Cut outs are illegal, but I've never seen anyone get screwed for them. If your car is crazy loud it can definitely land you in some heat, but if you putt the car around intersections and keep an eye out for cops it doesn't matter.
Old 03-03-2015, 12:13 AM
  #52
ZBeastZ
ZBeastZ's Avatar
With more air going through the engine though you need more fuel too correct? I don't want to run lean since this car is my DD. Will the plenum spacer require a tune afterwards or is it safe?
Old 03-03-2015, 03:37 AM
  #53
travlee
Master
travlee's Avatar
you will be lean and a tune would be preferred, although some people run them and dont tune. me personally i would get it and get tuned as soon as you can
Old 03-03-2015, 05:58 AM
  #54
Syner
Syner's Avatar
You should be fine without a tune for a while. I wouldn't tune until all the breather mods are done.
Old 03-03-2015, 07:07 AM
  #55
Cap11
Cap11's Avatar
The copper allows you to install it and forget that's it's there no matter what the ambient temp is. The isothermal comes with a valve on a coolant line that you open when the outside temp drops to around 55 degrees. Otherwise you leave the valve closed. You can read more about it at the Motordyne website.
Old 03-03-2015, 03:11 PM
  #56
ZBeastZ
ZBeastZ's Avatar
Some say tune some say dont haha. What's a while mean? Okay ill look into the differences between the materials. Thanks
Old 03-03-2015, 10:33 PM
  #57
Resmarted
Resmarted's Avatar
You don't need coolant going to your throttle body. Don't pay attention to all the iso whatever crap.
Wait to get your tune when you've done all your bolt ons. Or call into a place that does flash tuning and see if they could do a reduced price for a second tune... Its usually about $300 a flash though...
The 03's run pretty rich up top stock, I know that much. A tune with all boltons would really wake up the car.
Old 03-04-2015, 01:23 AM
  #58
ZBeastZ
ZBeastZ's Avatar
Okay I will wait for the tunes, are there any signs I can look out for though to know if my car being lean is destroying the motor? Also, is there a DIY guide for the plenum spacer?
Old 03-04-2015, 04:22 AM
  #59
Conway_160
Conway_160's Avatar
Here is your DYI,
Remove intake
Remove the air hoses on the left and rear
Remove all the bolts
Lift the upper plenum up slide in metal spacer and the plastic spacers.
Carefuly set down the upper plenum
Use new bolts and reatach every thing.
Good luck :-)
Old 03-04-2015, 07:13 AM
  #60
Syner
Syner's Avatar
Look on MD's website. They give the proper torque specs as well.
Quick Reply: Exhaust Ideas
