350z not cranking
Old 09-23-2016, 01:10 PM
Money1230
Money1230's Avatar
Default 350z not cranking
Hello, fellow Z owners.
I am having a little trouble starting the Z and would appreciate any suggestions or input.
So I have a 2005 350z 6speed, when i go to turn her on all the lights come on, fuel pump is priming and everything seems normal but when i go to crank it over there is nothing. Not cranking. Now the wierd part is if I reset the ecu twice it will start and everything is fine, runs great. That is untile i turn it off and try to start it again, then its just like the begaining.
Starter and battery are good.
Has anyone ever experienced this?
Old 09-23-2016, 06:19 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Check the plunger on your clutch, ive seen them cause problems before... The ecu thing is odd. If you have another key I would try that also.
Old 09-23-2016, 06:22 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
QFT. Different key. .02
Old 09-23-2016, 07:02 PM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
take it for proper diagnosis... my internet mechanic crystal ball (sponsored by webMD) says your car has gonorrhea
Old 09-24-2016, 08:22 PM
Money1230
Money1230's Avatar
Alright so the car sat for a whole day untouched and then today i went and it started right up, no problems. Its running great and not having the issue anymore. Didnt do anything but let it sit for a day.
kubech
10-16-2016 12:39 PM
Amy D'Anastasi
09-21-2016 09:31 AM
Quick Reply: 350z not cranking
