Radio/charger ports staying on (Mirror fuse)
on
Ok so my radio and 12V ports have been staying on intermittently after the key has been removed from the ignition. I was trying to remove the aux cable and the charger before turning off the car but it was still doing the same thing. This morning I started going through fuses and got to the fuse for the mirrors and when I removed the fuse the radio turned off. Where should I go from here?
The radio and mirrors work off one fuse and the 12V sockets off another, but both fuses should only receive power with the ignition switch in ACC or ON. Sounds like you may have a problem with your ignition switch.
Z1Motorsports
06-06-2017 08:06 AM
Speedgato
350Z Roadster
12-15-2016 01:53 PM
