Drivers side window stuck
Old 03-15-2017, 05:46 PM
Easterli
Easterli's Avatar
Default Drivers side window stuck
My driver side window is stuck, completely rolled down. We are going to replace the motor, switch, and regulator, but parts won't be delivered for a couple of days. Is there a way to get the window rolled up until the parts arrive?
Old 03-15-2017, 06:00 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Yes.
Take off the door panel, remove the lower access cover. Remove the 3 bolts that secure the window motor, remove motor.
Insert a 3/8" socket extension into the white plastic piece where the motor came out. Roll it up with the socket wrench and place 4 pieces of tape vertically from the inside glass over the top door frame then down the outside to hold it up.
Good luck w your repair.
Easterli (03-18-2017)
Old 03-16-2017, 04:26 AM
BjonesZ33
BjonesZ33's Avatar
same thing happened in my car, try holding the switch in the up position and slam the door pretty hard, worked for me and a bunch of other people. Hopefully works for you, good luck.
My drivers window motor died out the other day and just received my new one yesterday, hopefully the weather clears up a little this weekend so i can install it.
