SharX59's Build Thread
Old 12-06-2012, 01:51 AM
  #41
jdmlove1
jdmlove1's Avatar
mmmm sheesha!! i never knew americans smoke sheesha!! and the tobacco u have --> AL FAKHER .. u know they stopped this tobacco for a while in Bahrain!! not for healthy reasons for sure :P
Old 12-06-2012, 04:13 AM
  #42
pss350z
pss350z's Avatar
Originally Posted by SharX59
Will do! How about the master cylinder?
That's a ton of pad options....which would be good for both daily and occasional track and canyon duty
I have the wilwood master as well.... Mine is the original with the reservoir down low, new one i believe has been improved with the reservoir up top. The HD CSC is a must and the Wilwood complements it.... I was sick of my clutch issues so i went ahead and replaced everything.
Old 12-06-2012, 12:15 PM
  #43
SharX59
SharX59's Avatar
Sounds like a plan! Thanks for the heads up.
Yah, haha. Well I'm actually Persian-Armenian, but born in the great state of TEXAS!!!! We call it hookah in Cali, going to lounges that serve hookah is common.
Old 12-07-2012, 12:55 AM
  #44
SharX59
SharX59's Avatar
UPDATE: AGENCY POWER INSTALLED!!
install went well except i couldn't get the hanger ring to close flush...and ive been looking for a DIY for a single exhaust but i cant find it. I'm pretty sure I put it on incorrectly because at WOT rattle can be heard from the muffler. Any ideas guys?
Old 12-07-2012, 08:50 AM
  #45
SE5spd
SE5spd's Avatar
Salam pesar.
Old 12-11-2012, 09:30 PM
  #46
SharX59
SharX59's Avatar
Originally Posted by SE5spd
Salam pesar.
LMAO
Old 12-11-2012, 09:42 PM
  #47
SE5spd
SE5spd's Avatar
LMAO
Old 12-11-2012, 09:44 PM
  #48
SharX59
SharX59's Avatar
OKay so special thanks to THMotorsports!! They took care of me and were very efficient and helpful with my order.
The very well done packaging
<a href="http://s117.beta.photobucket.com/user/sharx59/media/7E465FED-D54D-487D-A3BC-5155DA822D24-11067-0000079A910CC347.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/7E465FED-D54D-487D-A3BC-5155DA822D24-11067-0000079A910CC347.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
<a href="http://s117.beta.photobucket.com/user/sharx59/media/095C1E69-DAC5-474C-93BA-F6FB9F82129F-11067-0000079AC8FD0533.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/095C1E69-DAC5-474C-93BA-F6FB9F82129F-11067-0000079AC8FD0533.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
Took the muffler section out...I literally stared at it for 2 minutes it was so mesmerizing...
<a href="http://s117.beta.photobucket.com/user/sharx59/media/4EE4BA8F-DD70-4178-910C-227789E0B67C-11067-0000079AF5D70C37.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/4EE4BA8F-DD70-4178-910C-227789E0B67C-11067-0000079AF5D70C37.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
Had my friend at Infiniti do the install
<a href="http://s117.beta.photobucket.com/user/sharx59/media/AFA76CE9-D324-4080-AC08-7E8032C4FA73-11067-0000079B10FEDC58.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/AFA76CE9-D324-4080-AC08-7E8032C4FA73-11067-0000079B10FEDC58.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
And there you have one freshly installed agency power single!!!
<a href="http://s117.beta.photobucket.com/user/sharx59/media/30B800A4-8332-45BC-9D23-62E17C222092-11067-0000079BCA2BCD29.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/30B800A4-8332-45BC-9D23-62E17C222092-11067-0000079BCA2BCD29.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
A day later I had my cousin drive the car so I could hear how she sounds....(just a 3rd gear pull I believe, if this video is against the rules I will gladly take it off )
Old 12-27-2012, 11:49 AM
  #49
SharX59
SharX59's Avatar
so there is a track event on the 19/20th of january. If I can order and install these parts before then I will finally be going back!
SPL Camber arms
Enkei wheel
JWT Clutch/Flywheel kit
Zspeed Clutch Slave
Hawk HP + pads
Then of course I will need an alignment and I will have to bleed both the clutch and brake systems.
Old 12-27-2012, 06:38 PM
  #50
SharX59
SharX59's Avatar
BUMPER TUCK DONE!
<a href="http://s117.beta.photobucket.com/user/sharx59/media/F812CB1B-10A0-439D-A1CF-99B22DCC9553-607-000000534A51F3B3.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/F812CB1B-10A0-439D-A1CF-99B22DCC9553-607-000000534A51F3B3.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
Old 12-28-2012, 02:54 AM
  #51
freddys 350z
freddys 350z's Avatar
nice progress. i run the same set up(kinda). ap single, art pipes, topspeed y pipe. i suggest you get the xyz pipe with resonator when you get the art pipes, or install resonators else where. it will need it if you wanna kill the rasp it has. i my self still need to get the resonator.
Old 12-28-2012, 10:33 PM
  #52
SharX59
SharX59's Avatar
Thanks! Do you mean rasp from the exhaust or the pipes? At the moment the exhaust has no rasp and is very deep.
Old 12-28-2012, 10:36 PM
  #53
freddys 350z
yeah, the the art pipes. when i had stock cats with ypipe and ap single the exhaust sounded perfect. when i added the art pipes i got all sorts of rasp, but its worth the mid range bump you can feel on the butt dyno.
Old 12-28-2012, 10:46 PM
  #54
SharX59
SharX59's Avatar
That's weird, I was under the impression that one of the best benefits of the art pipes is the fact that it doesn't cause rasp like regular test pipes...
Old 12-28-2012, 11:34 PM
  #55
freddys 350z
i never used test pipes, but i imagine they are a whole lot worse.
it might just be a combination with the AP since its a strait through design. but, i believe just adding the xyz pipe with resonator or hfc will solve the problem.
Old 12-28-2012, 11:36 PM
  #56
SharX59
SharX59's Avatar
Well thank you for the heads up!!
Old 01-08-2013, 06:15 PM
  #57
SharX59
SharX59's Avatar
UPDATE: SPL V3 Camber arms and ANOTHER enkei wheel ordered -_- ( i gotta stop bending them)
Old 01-13-2013, 08:01 PM
  #58
SharX59
SharX59's Avatar
So I headed down to 9K Racing to get my new arms and my enkei mounted.
CAMBER ARMSSSSSSSSSSS (so juicy)
<a href="http://s117.beta.photobucket.com/user/sharx59/media/5C53146E-4889-4A1B-9814-4FEAA771BC9E-12015-0000087BE0ECC319.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/5C53146E-4889-4A1B-9814-4FEAA771BC9E-12015-0000087BE0ECC319.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
No pix of the wheel because lazy, so ill put these here
<a href="http://s117.beta.photobucket.com/user/sharx59/media/9D124C31-C1CA-4630-A1C7-59E92C736428-12015-0000087BEF76BC7E.jpg.html" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/9D124C31-C1CA-4630-A1C7-59E92C736428-12015-0000087BEF76BC7E.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"/></a>
And nothings official unless you have stickers DDD "because race car"
Old 01-13-2013, 08:36 PM
  #59
freddys 350z
how are you bending the wheels?
not sure if you ever solved that ratting problem with the exhaust. but mine would tap against the diff. a little adjusting here and there pulled it away from the diff..also, the clamp is not supposed to close completely on the muffler.
Old 01-14-2013, 08:00 AM
  #60
SharX59
SharX59's Avatar
Well on the track have you have seen those red and white shoulders on the side, I clip those a tiny bit and I am assuming I hit then a little hard...
Oh boy do I have news for you! The rear section of the canister wasn't even welded on (still isn't)! So I need to contact agency power to warrenty the part. I'll post up a video of it later today. 9K discovered this while inspecting the car before install. If they hadn't shown me I would t have found out.
Quick Reply: SharX59's Build Thread
