SFR T-67 Single turbo system-Interest?
Old 03-02-2008, 09:31 AM
  #81
TurboTim
Vendor - Former Vendor
TurboTim's Avatar
Originally Posted by QuadCam
Tim,
Have you thought about making a simple driver's header (simple, as in similar to the OEM non-equal length design) that uses a V-band clamp on the outlet? A v-band would give you even more room to work with over the huge stock header outlet flange.
Keepiing the cost down for an entry level system is a concern.When we are making all the parts here in the US, it cost alot more then to do in China and with our target price, it doesnt leave alot of room to do things that are not neccessary, if you will. We opted for using three bolt flanges because a. they are cheap,b.they seal good especially when we use copper gaskets (which will come with the kits)and c.it makes it easier to line everthing up and not have to worry about exhaust leaks.
Old 03-02-2008, 09:53 AM
  #82
zmedic16
zmedic16's Avatar
will this kit fit the 06 rev ups? with the different steering racks?
Old 03-02-2008, 03:19 PM
  #83
jwttz
jwttz's Avatar
Iwill be next in line for this kit. when my engine is done.
Old 03-02-2008, 05:51 PM
  #84
TurboTim
TurboTim's Avatar
Yes. We are building the kit on a rev-up motor.
Old 03-02-2008, 05:55 PM
  #85
CRAYY Z
CRAYY Z's Avatar
hey tim, just makin sure you got my pm about my brothers email address....
Old 03-02-2008, 06:02 PM
  #86
soleil
NolaZcc
soleil's Avatar
i want this so bad
Old 03-02-2008, 06:06 PM
  #87
Mike Wazowski
Mike Wazowski's Avatar
Originally Posted by soleil350z
i want this so bad
Do it!!!
Old 03-02-2008, 06:14 PM
  #88
zmedic16
zmedic16's Avatar
from 05 to 06 there are different steering racks. u building this on an 06 car?
Old 03-02-2008, 06:19 PM
  #89
soleil
NolaZcc
soleil's Avatar
Originally Posted by USN HM 350Z
Do it!!!
i was just checking my finances and when its avalible i'm all over it
Old 03-02-2008, 09:51 PM
  #90
xcessiveskllzz
xcessiveskllzz's Avatar
so it won't fit the non rev ups?
Old 03-02-2008, 10:05 PM
  #91
accordfreak
accordfreak's Avatar
can't wait for the dyno!
Old 03-03-2008, 06:37 AM
  #92
NA&CH
NA&CH's Avatar
Hey Tim,
I see you went with the dual Exhaust setup.. Would one be able to have a single exhaust? I assume so... Straight from you guys without outside modding?
Thanks
Chris
Old 03-03-2008, 08:11 AM
  #93
TurboTim
TurboTim's Avatar
It will fit all VQ35DE's.No problem.We are doing this on an 06' G35 rev-up but we left room for the steering rack on all VQ35de's.
Old 03-03-2008, 08:14 AM
  #94
TurboTim
TurboTim's Avatar
Originally Posted by NA&CH
Hey Tim,
Thanks
Chris
We will end up doing as single exhaust set-up down the road.
Old 03-03-2008, 08:40 AM
  #95
Floridaboy1605
Floridaboy1605's Avatar
+1
Old 03-03-2008, 08:49 AM
  #96
down_shift
down_shift's Avatar
Curious bout the TN upgrade kit you mentioned in the first post.. Will this open up the cap on the TN kits? What does the kit include? more piping? New turbo? You said you are using a Spearco intercooler.. is that the same as in the TN kit?
thanks
Old 03-03-2008, 09:09 AM
  #97
TurboTim
TurboTim's Avatar
thanks
The stage 1 kit we are thinking of offering will include a new T4 hotside,all new exhaust plumbing to the turbo and out of the turbo.You will use your wastegate,turbocharger,oil lines,intercooler and piping,etc.......
The stage 2 system will consist of an intercooler upgrade and new piping kit. to go along with all the components of the stage 1 kit. The intercooler we are using will be bigger then the Turbonetics kit.
The stage 3 kit will come with a new turbo to go along with the components of the stage 2 system.
Old 03-03-2008, 10:43 AM
  #98
down_shift
down_shift's Avatar
So basically the stage 3 is a completely new kit minus the ecu lol.. Injectors come into mind.. will those be included in the kits? If the stage 0 (stock TN kit) gives you around 360-400rwhp.. what will the other stages bring for estimated rwhp?
Old 03-03-2008, 10:55 AM
  #99
TurboTim
TurboTim's Avatar
Not exactly because you can still use your oil feed lines,drain lines,BOV and wastegate
Those can be included in the kits but we feels as though most people will be doing their own EMS,injectors,etc...upgrades.By going to a larger hotside on the Turbonetics 60-1,it should allow you to make another 25WHP at the same boost level.By removing the restrictions in the exhaust,it should free up another 15WHP or so. So now you are looking at making over 400WHP out of the same turbo that is part of their kit.Overboosting with aftermarket exhausts will not be an issue either.
Old 03-03-2008, 12:26 PM
  #100
TayTaythatsme04
TayTaythatsme04's Avatar
Tim, so the Stage 1 upgrade will consist of the similar piping to the pictures already shown??
Any idea on what the wait time would be and what price range were looking at??
Thanks
T
Quick Reply: SFR T-67 Single turbo system-Interest?
