HOW TO: take of shift knob + adjust shifter guide plate
Old Nov 16, 2005 | 02:55 PM
pj550v12's Avatar
pj550v12
Default HOW TO: take of shift **** + adjust shifter guide plate
Well after getting my tranny replaced and feeling the knotch that felt like it didn't belong when shifting from 4th to 5th,
I figured there was something that could be done and sure enough a fellow Z member came through with some advice. So I took it upon myself to record the process and share it with you guys:
Reach in and pull up on metal ring surrounding shifter, it should pop up with a little force
Then just pull gently on the entire piece, its held in by clips which come free easily
You can disconnect this wire, but it was being a pain so I just let it be and placed the entire panel to the side
Now to disconnect the shift ****, place vice grips where shown, hold steady to counteract any stress being placed on the shifter itself when you unscrew the ****. Some people have snapped the shifter so dont skip the vice grips step.
Next there are 4 10mm bolts holding this plate in place, loosen them and pull the entire plate off. Be sure to first remove the cotton skirt, and rubber boot. NOTE there is a small brass ring above the rubber boot I didn't get a picture of, you'll see it though.
Now remove the second, smaller rubber boot
This will leave you with this
YOU'VE NOW REACHED THE ADJUSTMENT PLATE! Loosen these three bolts pointed to, do not remove. Press the entire plate as far to the left as posible, while pressing, tighten the bolts. Make sure to tighten them good since the shifter will be pressing against this plate some times.
You're now done, just put everything back together. One note, when puting the shift **** back on, hold the boot as the seems as such Name:  Picture017.jpg
so that the seems line up when you're done, rather than getting pulled with the turning of the ****.
Hope this helps!
Old Nov 16, 2005 | 02:57 PM
pj550v12's Avatar
pj550v12
Sorry some of the pics are huge guys I dont know why that happend. Also Mods, I know this might not be the right place for this, but can you leave it here at least for a day or so before you move it since I know there are a few people who are interested in this area.
Old Nov 16, 2005 | 03:51 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
good guide!
Old Nov 16, 2005 | 04:17 PM
MannishBoy's Avatar
MannishBoy
Sorry, moved it before I read the thread, but this really goes in this section.
Old Nov 16, 2005 | 04:19 PM
2004z's Avatar
2004z
Sleeps in 350Z
Did this fix the problem?
Old Nov 16, 2005 | 04:39 PM
MonkeyBoy's Avatar
MonkeyBoy
I knew about this when I had the problem, but instead just had Mossy Nissan fix it when I went it for a variety of complaints. Needless to say, I wish I had done it myself. Their solution? Thread-lock. Now I cannot take the shifter off.
Old Nov 16, 2005 | 04:50 PM
need Z's Avatar
need Z
Why/how does this fix the problem??? What does it change, just the position of the plate??
Old Nov 16, 2005 | 05:26 PM
hndumafia's Avatar
hndumafia
awesome. ive been needed to do this since my tranny was replaced like 2 years ago! i've just been too lazy to figure out how.
Old Nov 16, 2005 | 07:08 PM
pj550v12's Avatar
pj550v12
Yes this fixed the problem, and this is why. The little square metal piece you see on the lower right portion of the shifter, actually is supposed to hit the metal plate to stop it from moving over. My guess is that when dealers are replacing trannys they aren't taking the time to adjust this. Naturally, there is room for the shifter to move over to the right for reverse, but when you push the plate over to the left it stops it from going into that groove unless you push down on the shifter.
Old May 27, 2006 | 04:40 PM
ceevee's Avatar
ceevee
I just had my tranny replaced and this thread helped solved that annoying problem. Thanks! This guide could be in the Repairing section too.
Old May 29, 2006 | 07:49 AM
97supratt's Avatar
97supratt
Same here, at one point I was power shifting into 5th and it got stuck. I had to yank the shifter back to neutral with force. Thanks for the great guide!
Old Feb 24, 2018 | 01:34 PM
Accel's Avatar
Accel
Except that I am seeing pics of cars instead of parts. - still Greatly helped, Man thanks a lot
MM'08_350Z
Apr 22, 2021 09:42 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
