NEW - Stance 3-way Coilovers
I know this is a true rear coilover set up and mounts on the rear damper position. my question is, the Z was not designed for the suspension to have the load at this point, and neither was the frame that holds the rear damper. Has anyone had a failure on a Stance? Does anyone track a set of Stace coilovers and see any additional fatigue or failures?
I'm not clear on the adjustments on these. Is the high speed compression and rebound still done via one adjustment **** or can they be adjusted independently?
I've always considered triples (low speed adjustment) to be over my abilities to tune and will be curious to hear peoples experiences.
Where are the external reservoirs mounted and is all necessary hardware included to mount them?
thanks
thanks
Originally Posted by drumma022
Currently set to $1995, but I am sure there will be decent discounts as an introductory price.
Vince
They are a true 3-way. 2 ***** on the external reservoir and 1 **** for rebound on the coilover.
I am waiting for Stance to revise the lower mount for super low ride height. They should be here soon.
From what I've seen the Z gR3 is having some issues. I haven't heard anything more. drumma would be the guy for that. Currently nobody is taking orders for the 3's.
If you have questions regarding the differences please pm me. I don't want to muddy up this thread. But the basics don't use pillowball mounts and have a smaller piston diameter.
http://www.stance-usa.com/basic.php
Rishie
Rishie
#38
Shift_Dorifto
Originally Posted by kwiker
So can you buy these right now but just not have "super low ride height"? If so...what is the lowest you can get them? If this is the lowest then i will buy them now, b/c that is lower than i would ever go.
#40
Shift_Dorifto
Originally Posted by sflg35
i called stance today and they said they were still prototyping the gr3 and did not have a date when they would be ready for release
