FS: Tanabe sustec pro 7 coilovers
Tanabe sustec pro 7 coilovers "SOLD"
SOLD SOLD!!
Hi there, I have for sale a brand new set of Tanabe Sustec Pro 7 Coilovers, i bought these coil overs for setting up my tracked out G35 but i since then sold the car to purchase the brand new yamaha r1 bike. these coil overs will fit any year 350z or g35
I paid over 2,500 for these new and i never used them!
i have heard great thing about these coil overs from guys at the track and they perform like a bmw 7 series on the streets!! they put all the top coil over brands to shame with this specific model! they are also T.E.A.S compatible to change dampening inside the car by the click of a button!
please feel free to contact me via email/text or call if you have any more question!
626-230-9492
price is $1800.00
i can get reasonable shipping quotes for serious buyers!!
thank you.
brandon
Specs and info below:
SEVEN advances the technologies and greatest strengths of previous high performance Tanabe suspensions like the RR & DD even further. While similar in appearance, the SEVEN is completely different from any suspension currently available. The difference lies within the suspension itself and its highly unique internal construction and slide valve technology.
The new slide valve technology allows a great range of adjustability and function from both sides of the performance spectrum. (comfort to pure competitive motorsports use)
When used with the new TEAS electronic active suspension controller, the wide range of dampening force is accessible through the touch of a button, and is fully programmable to automatically adjust dampening rates according to the speed you drive.
In addition to TEAS, SEVEN is also available as a special "Hard Driving" version, for strictly motorsports use. (see below)
Competition Spec PRO210 Race Spring
A higher spring rate for motorsports application. Excellent handling, and most importantly, controllable traction is immediately noticeable through the use of the race developed spring. PRO210 was developed for extreme durability and balance. This spring has the highest tensile strength available due to our unique manufacturing process.
Case Length & Preload Adjustment, Dampening Adjustable
Both case length, and preload are adjustable. Preload can be adjusted for special settings, while full suspension stroke can be retained or altered with the case length settings. An extreme range of height settings are available with this suspension to suit any driver's needs or preferences for height and weight distribution. Dampening may be changed in 12 or 16(with TEAS) settings across a wide range of actual dampening force.
Ultra Heavy Duty Construction
The front suspension of a race vehicle experiences the most abuse, therefore a special dual plate stamped steel bracket is used. This bracket is extremely rugged and resists damage where most suspensions fall short. The rear suspension features a high tensile CNC forged aluminum knuckle that is both lightweight and rigid. The ruggedness of the bracketry on this suspension exceeds even OEM vehicle standards.
Reinforced Shock Piston, Reinforced Valving
The oversized Shock Piston is fully reinforced to resist flexing or snapping. The internal valving of the SEVEN is also fully reinforced for the increased and rapidly changing loads experienced during drifting. The internals resist oil and gas 'foaming' and overheating of the internal components which can detract from performance when driving under extreme conditions for extended amounts of time.
Durable Spring Seat & Lock Nut
Constructed of forged aluminum, longetivity and superior strength is ensured. Additionally, the threaded portion of the casing is chemically treated to resist rust and corrosion.
Upper Mounts Included
Solid mounting pillowball or rubber uppermounts are included on the front and rear of the Sustec Pro SEVEN. These uppermounts also have the added benefit of having front adjustable camber plates for fixing or modifying camber settings beyond factory limitations. Solid pillowball upper mounts prevent suspension geometry changes under various suspension loads.
Compatible with TEAS (Tanabe Electric Active Suspension)
By itself, SEVEN is an extremely solid multi-purpose suspension. With the new TEAS (Tanabe Electric Active Suspension) controller, SEVEN reaches new levels of suspension tuning. Sustec Pro SEVEN is 100% compatible with the TEAS controller and its actuators.
Spring Rates "Standard" 12.0kg/mm Front / 10.0kg/mm Rear
Spring Rates "Hard Driving" 14.0kg/mm Front / 12.0kg/mm Rear
626-230-9492
price is $1800.00
thank you.
brandon
Last edited by SR71; 12-29-2015 at 05:45 PM. Reason: Only suspension items allowed FS here
