UTEC / Hyperterminal driver HELP!
Old Aug 24, 2008 | 05:05 PM
hr2burn's Avatar
hr2burn
Default UTEC / Hyperterminal driver HELP!
Okay...bought a serial to USB cable. Followed instructions from TXS on setup. When it goes so setup the driver (Hyper terminal) I point it to the folder with the window drivers, it searches and says the file needed isnt in that directory. Re-downloaded the files from TXS, un zipped, same thing. I even let the hardware wizard search on it's own. What the hell?! Anyone else have this issue? Any guru's know what to do? I even looked in the system/hardware profile and it says no driver installed for that. Can't try different com settings...there is only one available to choose (com 3)
GRRRRRRRRRR!
Sean
P.S. searched this site for hours and no solution found
Old Aug 24, 2008 | 06:45 PM
athenG's Avatar
athenG
Did you install the driver from your Serial-USB cable? The TXS USB driver is if you want to use a straight USB connection.
Old Aug 24, 2008 | 07:56 PM
Barzten1's Avatar
Barzten1
subscribe
Old Aug 25, 2008 | 07:04 AM
RandomHer0's Avatar
RandomHer0
You should be using the driver that came with your Serial-USB Adapter. When I bought mine the manufacturer provided the drivers on a CD.
Old Aug 25, 2008 | 07:35 AM
RandomHer0's Avatar
RandomHer0
Also, why not just use USB?
Old Aug 25, 2008 | 09:49 AM
mangoman4u's Avatar
mangoman4u
Default +1
+1
Yeah I had the same difficulty using the driver that CAME WITH THE ADAPTOR (Belkin). I ended up just using the USB.
Old Aug 25, 2008 | 11:25 AM
AmateuRN's Avatar
AmateuRN
Ditto^ Had to go to the website of the serial-USB cable maker and download some files, install them, THEN open up HT.
Old Aug 25, 2008 | 02:46 PM
hr2burn's Avatar
hr2burn
Yeah...I don't know why this seems dumb to me...."back in my day" a cable was a cable...Hidden in the package was a tiny CD...file size was like 150K....Fixed it.
Thanks Athen and everyone else who hit it on the head.
Sean
Old Aug 25, 2008 | 02:47 PM
hr2burn's Avatar
hr2burn
Maybe I'm missing something else...but my UTEC is serial only and my lap top is USB only.
Old Aug 26, 2008 | 06:07 AM
gothchick's Avatar
gothchick
+1
This is what I had to do as well. Don't use the TXS USB drivers if you're using a Serial to USB adapter, use the drivers that came with the adapter.
Old Aug 26, 2008 | 07:23 AM
athenG's Avatar
athenG
Utec has another output for a straight USB. Go look at the back and you'll see a USB connection.
Old Aug 26, 2008 | 08:03 AM
QuadCam's Avatar
QuadCam
you only need a usb-serial adapter if you are going to run a UTEC and the TXS Tuner wideband. if you are running just the UTEC, use the direct usb connection on the utec.
Old Aug 26, 2008 | 08:34 AM
Barzten1's Avatar
Barzten1
I will be using the UTEC Tuner Wideband
Old Aug 26, 2008 | 09:39 AM
athenG's Avatar
athenG
Unless your laptop has a Serial Connection then you will need a Serial-USB because the Tuner only have a Serial connection.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
