So I have the chance to buy some on craigslist for $575. They come with tires but the rears are shot. Also come with TPMS but I don't think they will work with the 350z.
350z studs will work just fine. It's the offset of the front 370z wheels that sucks.
Thanks MR. Sparco. I finally got a set, probably overpaid but they were 100% clean and came with tire sensors that I will sell. Rear tires are trash but I will find some nice ones to upgrade to.
I've read in this thread that spacers are needed in the front, is 20 or 25 mm prefered as I've read some conflicting information.
So I'm replacing the rear tires as they have no tread. But the fronts still have 6-8/32nds of tread. Only problem is dry rot, not in the sidewall but between the tread.
I have a 2003 350Z with 18" V1 Touring Wheels(5spoke). Stock brakes(not bemboro) set up. Front is 18x8 with +30mm offset and rear is 18x8 with +30mm offset. I recently purchased a set of 18" 2010-2014 370Z Wheels(10spoke). Front is 18x8 +43mm offset and rear is 18x9 +15mm offset. I have 2 questions:
Will I need spacers to run these wheels?
TPMS. Can I put the 2003 sensors in the new wheels and everything will work on the dash and gauges?
I dunno man those bemboro brakes help make the wheels sit perfect, if you don't have them I wouldn't use the 370z wheels because your gonna have a bad time.
