ZROC (Z Car Roadster Owner Club) Forum for the Z Car Roadster Owner Club (ZROC) out of Columbus, Ohio.
Aeroforce Interceptor - car needed to add parameters
Old 07-05-2013, 11:13 PM
superlim9
superlim9's Avatar
Default Aeroforce Interceptor - car needed to add parameters
Anybody in the North Ridgeville, OH area with an '05 enthusiast or better with stock ECM?
Been talking with Aeroforce Tech about getting some parameters, to monitor the stock pre-cat O2 sensors, added to their interceptor gauge but they need one in the shop to do it. Said it would only take about 30 min.
I've got some posts in the forum on their site if someone wouldn't mind posting in there if they are in the area. 2,400 miles is to far to drive for 30 minutes of work.
I'm Located in Seattle so that's a little bit of a drive otherwise I would be all over this.
This is a good option for those that want to replace the center console gauges and not use an A-pillar pod. More information then the stock data gauge. Just no TPMS, Timers or DTE. but has
1. IAT – Intake Air Temperature
2. COOLANT – engine coolant temperature
3. RPM – engine speed
4. MAP – Manifold Air Pressure or boost (not supported on most Toyotas
5. MAF lb/min – Mass Air Flow in lbs per minute
6. MPH – Miles Per Hour
7. THROTTLE PCT – percent of throttle opening
8. IGN. ADV – Ignition Advance
9. STFT B1S1 – Short Term Fuel Trim bank 1 sensor 1
10. STFT B2S1 – Short Term Fuel Trim bank 2 sensor 1
11. LTFT B1S1 - Long Term Fuel Trim bank 1 sensor 1
12. LTFT B2S1 - Long Term Fuel Trim bank 2 sensor 1
13. ENGINE LOAD – PCM calculated percent of engine load
14. FUEL STATUS – Open or Closed loop operation
15. MPG – calculated fuel economy
16. HP – calculated horsepower
17. AT TEMP – Automatic Transmission temperature
18. INJ. PW – Injector Pulse Width in msec.
19. MISFIRES – total misfires of all cylinders per 600 rpms
just trying to get someone close that can go in to get a few more added... also could ask for them to try for tpms as well.
Thanks
SpartanZ32
10-22-2015 09:36 AM
codek
09-27-2015 03:21 PM
Mikey R6
09-19-2015 01:48 AM
Quick Reply: Aeroforce Interceptor - car needed to add parameters
