Tire feathering TSB question
Ok we all know that there are TSB's out there for the tire feathering. Most dealers do these TSB's no problem, but what if you have aftermarket suspension. Will they still do it or are you on your own? Not that I would expect them to do a TSB relateing to the suspension when I have aftermarket suspension on but there is one that is willing to do it hell why not.
The worst thing you can do is try, but you better make sure your tires are actually feathered and not just worn on the inside from excessive negative camber from your lowering which I know increases negative camber in the front. Looks like you have rims as well, so what do you plan to do put the stock wheels back on?
Well what are you expecting them to do when you take it in? They won't replace your aftermarket tires, that is for sure. They might be able to give you a free alignment and make sure your toe is correct.
350Z_Al
Oct 29, 2020 07:44 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
